Window relay location 1966
1966vernon
Postby 1966vernon » Tue Apr 11, 2023 6:54 pm
Needing to access, test, and likely replace the power window relay. Where exactly is it, and best way to access it. Kick panels are off. I'm getting conflicting info on which side of the column? I know about what I'm looking for and just can't seem to see it i guess. I'm wanting to rip apart as little as possible and not rebuilding anything. This is a survivor, just wanting to fix it and get it functional.
Thanks for any help on this.
Justin Mayes
1966, 88k miles, absolute family survivor
Jelonek
Years Owned: 1
Re: Window relay location 1966
Postby Jelonek » Sat Apr 15, 2023 2:46 am
I can’t help your :| I don’t know where is it and I hope somebody knows where is it ….. that’s a very interesting problem
Willysnut1959
Postby Willysnut1959 » Thu Feb 22, 2024 9:48 am
I don't believe that the windows or seat utilizes relays. Power is transmitted only through the switches
Ourkid2000
Postby Ourkid2000 » Fri Feb 23, 2024 5:26 am
The relay for the power windows should be located here.......drivers side kick panel (from the Fisher Body Manual):
I have also highlighted the relay in the attached wiring diagram from the CSM.
Hope this helps!
Ourkid2000
Postby Ourkid2000 » Fri Feb 23, 2024 10:27 am
From the Fisher manual electrical section - pg 11-7
Lipient
TOA Membership Number: 127
does insurance cover dapoxetine
Postby Lipient » Fri Nov 08, 2024 4:49 pm
We examined the changes over a 4 month time period as this time period is similar to that often used for the radionuclide scintigraphy and magnetic resonance imaging studies of gastric emptying 25 <a href=https://fastpriligy.top/>priligy canada</a>
