Needing to access, test, and likely replace the power window relay. Where exactly is it, and best way to access it. Kick panels are off. I'm getting conflicting info on which side of the column? I know about what I'm looking for and just can't seem to see it i guess. I'm wanting to rip apart as little as possible and not rebuilding anything. This is a survivor, just wanting to fix it and get it functional.
Thanks for any help on this.
Justin Mayes
1966, 88k miles, absolute family survivor
Window relay location 1966
1966vernon
Re: Window relay location 1966
I can’t help your
I don’t know where is it and I hope somebody knows where is it ….. that’s a very interesting problem
Willysnut1959
I don't believe that the windows or seat utilizes relays. Power is transmitted only through the switches
Ourkid2000
The relay for the power windows should be located here.......drivers side kick panel (from the Fisher Body Manual):
I have also highlighted the relay in the attached wiring diagram from the CSM.
Hope this helps!
Hope this helps!
- windowrelay1.png (158.72 KiB) Viewed 6914 times
- windowrelay.png (203.9 KiB) Viewed 6914 times
Ourkid2000
From the Fisher manual electrical section - pg 11-7
- windowrelay2.PNG (8.45 KiB) Viewed 6890 times
does insurance cover dapoxetine
We examined the changes over a 4 month time period as this time period is similar to that often used for the radionuclide scintigraphy and magnetic resonance imaging studies of gastric emptying 25 <a href=https://fastpriligy.top/>priligy canada</a>
