Fuel line from pump to carb, 1970 Toro
Eightballz
TOA Membership Number: 826
Postby Eightballz » Thu Dec 22, 2011 2:54 am
do u guys have any idea where i can get that fuel line?
car is 1970 olds toro GT
Hasty
TOA Membership Number: 765
Years Owned: 1970 Toronado GT
Re: Fuel line from pump to carb, 1970 Toro
Postby Hasty » Thu Dec 22, 2011 4:26 am
You may have to buy a straight piece, and bend it and flare it yourself. Not a hard job, with a little patience.
St. Cloud, MN
1970 Toronado GT
TOA #765
Postby Twilight Fenrir » Thu Dec 22, 2011 8:19 am
I bought a braided steel line from jeggs... It's much nicer imo
Eightballz
Postby Eightballz » Tue Dec 27, 2011 1:49 pm
Twilight Fenrir wrote:I bought a braided steel line from jeggs... It's much nicer imo
...and this was pre-bent?
Postby Twilight Fenrir » Mon Jan 02, 2012 7:57 am
It is braided stainless, it is flexible, like a faucet supply line. It is badically a hose wrapped with stainless steel mesh. Cut to length, put the two fittings on, and good to go!
toro_mike
Contact:
Postby toro_mike » Wed Jan 04, 2012 2:58 pm
You are pretty much confined to bending one yourself or finding one in a junk yard. They just aren't available. Inline Tube may be able to help, but you may need to supply the proper length and details. I'm not sure.
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
Postby xgecko » Sun Jan 08, 2012 3:47 pm
I have a bit of solid tube at each end with modern rubber gas line between for now. Once I convert to Fuel Injection later this season I will be bending custom lines.
hbarbee
TOA Membership Number: 1035
Years Owned: 1969
Postby hbarbee » Tue Jun 26, 2012 8:33 pm
I used this opportunity to buy the metal ends and install a metal in line fuel filter between with short rubber fuel hoses to connect them. That gives you the flexibility to make the line fit. The extra filter always helps.
HBARBEE 1969
