do u guys have any idea where i can get that fuel line?
car is 1970 olds toro GT
Fuel line from pump to carb, 1970 Toro
- Eightballz
- TOA Membership Number: 826
- Unbenannt.png (67.34 KiB) Viewed 16400 times
Hasty
- TOA Membership Number: 765
- Years Owned: 1970 Toronado GT
Re: Fuel line from pump to carb, 1970 Toro
You may have to buy a straight piece, and bend it and flare it yourself. Not a hard job, with a little patience.
St. Cloud, MN
1970 Toronado GT
TOA #765
1970 Toronado GT
TOA #765
I bought a braided steel line from jeggs... It's much nicer imo
- Eightballz
Twilight Fenrir wrote:I bought a braided steel line from jeggs... It's much nicer imo
...and this was pre-bent?
Eightballz wrote:Twilight Fenrir wrote:I bought a braided steel line from jeggs... It's much nicer imo
It is braided stainless, it is flexible, like a faucet supply line. It is badically a hose wrapped with stainless steel mesh. Cut to length, put the two fittings on, and good to go!
- toro_mike
- TOA Membership Number: 4
- Contact:
You are pretty much confined to bending one yourself or finding one in a junk yard. They just aren't available. Inline Tube may be able to help, but you may need to supply the proper length and details. I'm not sure.
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
I have a bit of solid tube at each end with modern rubber gas line between for now. Once I convert to Fuel Injection later this season I will be bending custom lines.
hbarbee
- TOA Membership Number: 1035
- Years Owned: 1969
I used this opportunity to buy the metal ends and install a metal in line fuel filter between with short rubber fuel hoses to connect them. That gives you the flexibility to make the line fit. The extra filter always helps.
HBARBEE 1969
