Hello from Germany!
Re: Hello from Germany!
I never check it. It's not really necessary on "modern" vehicles.
Jelonek wrote: I worked last time with my friends on old Chevy from 1965 and 1966...
how often do you check the valve clearance...
Is the clearance for the in .. and exhaust the same ? 0,001 -0,003"
I am quite certain this car used hydraulic valve lifters, which do not require
adjustment. Bruce Roe
Thanks, guys for a quick and expert answer. Now I'm a little smarter too.
Hi everybody!
couse of aktually situation
I have a time and I want to put a new casget and instal intake manifold.
what is the torque for screws ??? I can´t find it in internet ..
thanks a lot! and be careful !
- 3.jpg (228.06 KiB) Viewed 59949 times
- 2.jpg (168.43 KiB) Viewed 59949 times
- 1.jpg (219.47 KiB) Viewed 59949 times
Hi Jelonek.
Have you not purchased a 1966 Oldsmobile Chassis Service Manual , yet?
https://www.ebay.com/itm/1966-OLDSMOBIL ... XQDfdRo7zG
Page 6B-47 lists all the torque Specs for the engine.
Cylinder Head to Block 80 foot pounds
Intake Manifold to Cylinder Head Bolts 35 foot pounds
All the above bolts must be dipped in oil prior to installation for correct torque readings
Thanks a lot! Otto, after your mail I found this to
I hope to finish my work today und to start the engine again .
What happened, Jelonek? Why are you doing this work? Did you blow a head gasket?
no... nothing bad but I had a problem withe the intake-gasket at the front , lekage, leaking,
last summer a got a new gasket and the work ist not so complicated, even ignition don´t musst be disassembled,
the Intake is a very heavy, so I built a pulley to put it with feeling ...
so today i want to refill the coolingsystem and drive again
some pics after the work
- 312.jpg (205.65 KiB) Viewed 59931 times
- 212.jpg (159.15 KiB) Viewed 59931 times
- 112.jpg (194.05 KiB) Viewed 59931 times
