Anyone know a secret to remove emblem from tilt/tele wheel?
zentoed
Years Owned: 2 days
Postby zentoed » Wed Sep 09, 2015 9:05 am
The manual says push in and turn counterclockwise... no movement at all.
This is on a 1966 Toronado.
Thanks in advance
zentoed
Years Owned: 2 days
Re: Anyone know a secret to remove emblem from tilt/tele whe
Postby zentoed » Thu Sep 17, 2015 5:13 am
figured it out...
Postby Otto Skorzeny » Thu Sep 17, 2015 6:10 pm
Tell us how you did it. Is there really a secret or was yours just corroded or something? I have a '66 and don't plan on removing the wheel but you never know.
zentoed
Years Owned: 2 days
Postby zentoed » Sun Nov 01, 2015 7:42 am
I was reluctant to apply much force, the manual says push in and turn, I saw no movement when I pushed in. Once I accepted the possibility of breaking the emblem and having slim chance of a replacement being available, it was easy. Turns out all I needed to do was gently pry it straight out with plastic pry bar.
Postby Otto Skorzeny » Sun Nov 01, 2015 8:28 am
Which way do you rotate it after pushing in? Did you pry it out after pushing in and turning or did you just pry it out without the push and turn method?
B57-1974
Re: Anyone know a secret to remove emblem from tilt/tele wheel?
Postby B57-1974 » Sat Jul 22, 2017 10:00 am
I am getting ready to try this on my steering wheel. I will let you know if it was push, twist and pry or just pry only.
B57-1974
Postby B57-1974 » Sat Jul 22, 2017 5:56 pm
OK, I did read the manual (the link was posted here, thanks!) and it does indicate that the "tilt and travel" steering wheel emblem should be push, twist and pry; however, mine was definitely pry only. It was very easy to pry off. It has four bent tabs that hold it on. You can see them in the picture.
