Removing Old Gasoline Part II
Re: Removing Old Gasoline Part II
Postby Otto Skorzeny » Thu Jul 10, 2014 2:16 pm
The next four pics show the long bolts that hold the straps at the front of the tank. As they are released, the straps will act sort of like a hinge and lower the tank at the front , pivoting at the rear where the straps hook into the slots.
The front of the car is at the top of the photos
Postby Otto Skorzeny » Thu Jul 10, 2014 2:27 pm
Notice the position of the fuel line and don't forget the ground wire connection by my finger.
Scrape off the undercoating if you can. Hopefully you don't have a lot of rust. If you do, soak the daylights out of the threaded rod and nuts with penetrating oil. The best stuff is a home brew of 50/50 transmission fluid and Acetone. Put it in a little can and paint it in there with a toothbrush or put it in an old Windex bottle
