Alternator Replacement
maxsonrj
- Years Owned: 1969. I am a member but do not know TOA number
I replaced my alternator. It seems to be charging fine but my alternator light is now on all the time. I read somewhere about older cars having an external regulator. Can there be a problem with installing a new alternator on a 1969 toro? I assume my new alternator has an internal regulator..
maxsonrj wrote:I replaced my alternator. It seems to be charging fine but my alternator light is now on all the time. I read somewhere about older cars having an external regulator. Can there be a problem with installing a new alternator on a 1969 toro? I assume my new alternator has an internal regulator..
You absolutely don't want an internally regulated alternator installed in a car
with an external regulator (like a 69). I don't even want to think of what might
happen.
On the other hand, you could convert the car by removing the mechanical
regulator and some wires. I think there is even a jumper harness to do this. Bruce Roe
Re: Alternator Replacement
Why do you assume that your new alternator is internally regulated? Did you not purchase an alternator designed for your car?
maxsonrj
I meant to put a question mark at the end of that sentence. I did get one from autozone for the car. A post I saw somewhere else had me worried that new alternators had internal regulators. Looks like I need to look else where for the problem. Thanks for your comments.
1977 Cutly
- TOA Membership Number: 1059
- Years Owned: 1966 Toronados
1977 Cutlass Supreme
does anyone still offer a rebuild kit?
From my experience you generally have to source your own parts rather than buying a one stop shop kit.
Rock Auto sells the bearings, brushes, brush holders, rectifiers, etc. but not as a complete kit.
