Power steering hose
Chazzer
TOA Membership Number: 146
Power steering hose
Postby Chazzer » Sun Jan 27, 2013 12:55 pm
Howdy all,
Anybody have a source for power steering hoses? My 68 has the power steering cooler. I initial ordered one from USA parts but it was incorrect as it is for none power steering cooler vehicle.
Cheers, Jim
TOA# 146
deaddds
TOA Membership Number: 8
Re: Power steering hose
Postby deaddds » Fri Feb 08, 2013 5:50 pm
I just got both pressure and return lines for my 67 at Federated Auto. He had to look it up in a book AND I had to use my tube bender where it hooks up on the pump to clear but it will work fine.
1970w34
TOA Membership Number: 38
Years Owned: 1970 multiple
Postby 1970w34 » Wed May 15, 2013 6:12 pm
I'm pretty sure that the Omega brand #535 will work for the pressure side.
Chazzer
Postby Chazzer » Fri Jul 26, 2013 7:57 am
Thanks...Weird though I checkout the Omega site and they list 5073. Do you think the listing 5073 is incorrect?
Cheers, Jim
TOA# 146
1970w34
Postby 1970w34 » Sat Jul 27, 2013 11:06 am
The number I posted was from some time back and what I got did fit though it was not exactly like the stock one. Let me take a look to see if the box says anything different than the order form and I'll get back with you.
Chazzer
Postby Chazzer » Sun Jul 28, 2013 5:08 am
Right on! Thanks 1970w34!
How about this one: Are the heater hoses moulded? I'm referring specifically to the rear hose that runs from the heater to the thermostat vacuum control that is mounted on the rear of the engine. I believe it is used to control the coolant flow from the engine block to heater core.
I tried a regular hose and found it wants to collapse.
Cheers, Jim
TOA# 146
1970w34
Postby 1970w34 » Tue Jul 30, 2013 11:22 am
Hey Chazz, I checked the box and it says 535 on it, no other numbers. As I stated though, that was from a few years back--maybe the numbers have changed? Hope that helps
