On my 1966 Toronado standard Engine and Carb. always cranks 15 to 20 seconds before it gets gas to start after it has been setting a day or more. Some people tell me the timing is off, Some say the gas drains back thru the lines, others say its not uncommon, others say it drains from the floats into the manifold,Greg would know. What due you think??
Flue Pump. Not the worst problem to have as long as the battery is good. Thanks in advance. Bob
Toro Slow Start
Robert Lindberg
- TOA Membership Number: 693
- Years Owned: 4 years 1966 Toronado
Re: Toro Slow Start
I'll tell you I've had the same problem on various old cars I've had. I've heard many of the same culprits as you and some new ones like ethanol, evaporation and a missing check ball. I've had some cars that would start right up after sitting for two weeks while others that sat for a day would take a bit of cranking to get going. All were in a good state of tune. I've deducted that the problem is the well plug in the carb that allows the fuel to drain. In the past, whenever I've had carb problems with other old cars I would replace the carb with a new unit like Holley Edelbrock. With the Toro though it seems I've got to send it out for a rebuild. I'm working with Sparky now and plan to send the carb to him once the weather gets really cold.
Chris
Chris
Re: Toro Slow Start
I've had this identical problem for the entire 9 years that I have owned my 1968 Toronado. Everything was tried, except for one: an auxiliary electric fuel pump.
Single-engine airplanes have these to draw fuel from the wings to the engine. Usually they're only used during starting, takeoff and landing (the critical times). During regular flight, the engine's mechanical pump is sufficient to continuously feed fuel to the engine.
Next time I bring the Toro to my mechanic for anything, he will install one. Together we'll determine how many second of pump activation is required to bring gas from the tank to the carb. Of course I will update this forum, but it might not be for quite a while, since everything else seems to be working perfectly.
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
- Fabio Herrero
- Contact:
Re: Toro Slow Start
I have the same problem and wanted to fix it someday.
By the time you put an electric pump for use only before giving boot.
Tengo el mismo problema y quisiera algun dia poder solucionarlo.
Por el momento coloque una bomba electrica que uso solo para antes de dar arranque.
Re: Toro Slow Start
Good news, I had the electric auxiliary fuel pump installed. In the future I will try to write a report about this in our magazine. The bottom line is that I am very pleased with the result.
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
Re: Toro Slow Start
Quadrajet carbs ARE known for leakage out of the well-plugs, and the early carbs are worse in this regard than the later ones.
That said, improper/excessive heating of the manifold coupled to modern-blend gasoline results in the fuel evaporating/boiling out of the float bowl, this evaporation can be greater than the fuel lost due to leaking plugs.
Aside from assuring that the heat riser is working properly and the exhaust is not restricted, the practical "fix" for this is a electric fuel pump that can prime the carb before and during cranking.
