67 Toro Engine?
greg
TOA Membership Number: 729
Years Owned: 66-70 (looking, would like to own)
67 Toro Engine?
Postby greg » Thu Feb 10, 2011 5:30 pm
Perhaps a silly question, but will throw it out here. I've been looking at a '67 on-line that is currently for sale. The seller tells me that the engine is original to the car, but I'm rather skeptical because of the photo below. I've never seen a '66 or '67 that didn't have the dual-snorkel air cleaner housing. It is most likely a motor from a 68-70, but wondering if there's any chance at all that some late-build 67s might have an engine like this? If I get one of these cars, I want one that is as close as possible to the model-year standard. Any insight appreciated.
TOA Membership Number: 839
Re: 67 Toro Engine?
Postby Twilight Fenrir » Thu Feb 10, 2011 6:09 pm
Well, im not an expert, but that looks like the appropriate engine. The oil-fill tube looks just like my '66, and the color is usually a good tipoff unless it has been painted. Toro's were the only car to have a slate blue engine. That being said, that aircleaner is from a much later model small block. Looks just like the one on my 82 el camino.
deaddds
Re: 67 Toro Engine?
Postby deaddds » Thu Feb 10, 2011 8:42 pm
Unsure about casting#s until I dig out a 67 service manual but it looks like a 425 but a 2nd gen air cleaner.
greg
Re: 67 Toro Engine?
Postby greg » Mon Feb 14, 2011 3:12 pm
Thanks all. Here's another question...
Cracked dashboards and steering wheels -- extremely difficult to replace? if good ones can be found ???
Re: 67 Toro Engine?
Postby Twilight Fenrir » Mon Feb 14, 2011 9:41 pm
greg wrote:Thanks all. Here's another question...
Well, not too sure on finding vintage Dashes, Justdashes.com has units listed for first-gen Toronado's though
http://justdashes.com/Products.htm
As far as the steering wheel goes, I've never seen one that wasn't cracked. That being said, this place here restores them. And if you look down near the bottom of their gallery, there's a Toro wheel even.
http://www.garyssteeringwheel.com/gallery.htm
greg
Re: 67 Toro Engine?
Postby greg » Tue Feb 15, 2011 9:31 am
Wow...excellent info, Twilight. Much appreciated!
roland
TOA Membership Number: 860
Re: 67 Toro Engine?
Postby roland » Sat Mar 05, 2011 4:33 am
@ greg
If your '67 engine problem isn´t finished:
All 66 and 67 Oldsmobile 425 V-8 can be identified by an engine unit number that stamped on a machined pad on the front of the RH cylinder head (behind the alternator). A Toronado engine should begin with a single letter prefix (ident the basic engine displacement), followed by unit number and a further letter (ident for a special high performance version)
Should be then:
1966 and 1967 - N (unit number) T
The 425 block casting number is located at the front of the block, between the intake manifold and the timing chain cover.
1966 to 1967 - 389244
Casting number of 1966 cylinder head is located just below the valve cover in the middle of the head on the exhaust outlet.
Should be 1966 - 389359 or 1967 - 394548
From 1968 till 1976 the 455 Toronado engine unit numbers are stamped onto the oil fill tube (should not used for identification because it is easily switched!).
1968 - US or UT
1969 - US, UT, UV or UW
1970 - US, UT, UV or UW
The block casting number (much better for ident) is located at the front of the block, between the intake manifold and the timing chain cover.
1968 to 1976 - 396021
Casting number of 1968 cylinder head is located just below the valve cover in the middle of the head on the exhaust outlet.
1968 to 1969 - 394548
1970 - 403686 or (W30 only) 404438
Hope it helps :P
Roland TOA#860
Roland TOA#860
hnoor0044
TOA Membership Number: 1
Re: 67 Toro Engine?
Postby hnoor0044 » Fri Mar 18, 2016 12:00 am
thinks for sharing the post
accictape
TOA Membership Number: 411
is it safe to take 2 tadalafil tablets
Postby accictape » Fri May 31, 2024 7:57 pm
Allergies have almost completely gone away <a href=http://cialis.lat/discover-the-best-prices-for-cialis>can i buy cialis without a prescription</a> Khuleshwari K, et al
Re: 67 Toro Engine?
Postby xeror » Wed Jul 23, 2025 2:52 pm
