'67 Turn Signal Switch
toro_mike
Contact:
Re: '67 Turn Signal Switch
Postby toro_mike » Sat Apr 10, 2010 5:11 pm
rt_toro_67 wrote:Any resources on finding a '67 shop/service manual online? I think I may have found one on CD-ROM, which is fine, but it also says "parts manual" so I hope it's actually a shop/service manual.
I have the Detroit Iron CD manual for my 1968 Toronado. It is well done and has everything you need. I picked mine up on eBay.
btw: I'll check my 68 manual and the spare column in the garage to see what it looks like.
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
rmeurer
TOA Membership Number: 402
Years Owned: 1968
Postby rmeurer » Mon May 24, 2010 5:04 pm
I got the switch out. My question is how do you pull the wires out with the connector on the other end. I would prefer not the cut the connector off.
Has anyone else had any luck getting this switch from the cadilacsonly.com site?
wires going through steering column. connector on end.
rt_toro_67
TOA Membership Number: 750
Postby rt_toro_67 » Fri Jun 18, 2010 12:29 pm
Since I started this thread I figured I should follow up even though I waited too long to do so. It turns out that the flared edge of the steering column is most definitely normal. I was lucky as hell to find a '67 tilt/telescoping column with an operative TS switch on EBay about a year ago, and we ended up swapping the whole column to avoid having to pull the switch.
I did buy the Detroit Iron shop manual on CD and I'm sure anyone else that has this can attest that it's a wise purchase. You can even see in the shop manual that the flared edge "lip" is used in combination with a specialty tool to pull that sleeve off to get the switch out.
Rmeurer, sorry I can't help with your question, I don't know about pulling the switch since we avoided doing so. I sure wish you luck on finding a switch...I'm already worried about what I'm going to do if I need another one of these switches that is now made of "unobtanium" in the future. Let us know if you have any luck anywhere.
rmeurer
Years Owned: 1968
Postby rmeurer » Mon Jun 21, 2010 7:18 am
Thanks for the Reply. I did find the switch for $250.00. If anyone has any idea on how to get the switch out please let me know. THanks
accictape
TOA Membership Number: 411
tadalafil work after activity
Postby accictape » Sun Jun 30, 2024 5:09 pm
Comparative study of concentration of isoflavones and lignans in plasma and prostatic tissues of normal control and benign prostatic hyperplasia <a href=http://cialis.lat/discover-the-best-prices-for-cialis>cheap cialis no prescription</a> Have yall started TTC yet
accictape
priligy uruguay
Postby accictape » Wed Sep 25, 2024 9:58 am
levitra teva cloxacillin 500mg side effects Amazing <a href=https://enhanceyourlife.mom/>priligy cvs</a>
Lipient
TOA Membership Number: 127
tab dapoxetine uses in hindi
Postby Lipient » Sun Nov 10, 2024 2:43 am
In addition to their known effects on sodium metabolism diuretic agents also exert profound effects on calcium metabolism <a href=https://fastpriligy.top/>pastillas priligy en mexico</a> The cells were treated with
Lipient
priligy vs cialis
Postby Lipient » Sun Nov 17, 2024 6:49 am
Misleading LASIK Advertising <a href=https://fastpriligy.top/>order priligy online</a> Daniel F B Wright, Lisa K Stamp, Tony R Merriman, Murray L Barclay, Stephen B Duffull, Nicholas H G Holford European Journal of Clinical Pharmacology 2013, 69 7 1411 21
