Hi all,
I've been into Toronados since before my first car, a 1969 Toronado, in 1978. Over time I have picked up many parts from ebay, salvage yards, a parts car, and saved, stored, and moved them around with me. Since I sold my 68 a couple years ago, it’s time to let the rest go.
I think it could all fit in a pickup truck to be transported from my house in the Oklahoma City area. Buyer pick up - $250 for the lot.
Please email me with any questions!
Thanks,
John Carpenter
67 Toro Air Cleaner Emblem Dk Blue (little rough)
68 Headlight Surround LH - 1 missing tab
68 Headlight Surround RH - 0 missing tab
68 Headlight Surround RH - 1 missing tab
68 Headlight Surround RH - 2 missling tabs
68 Toro 455 AC Compressor Bracket
68 Toro 455 Alternator Bracket
68 Toro 455 Head Bolts
68 Toro 455 Heads - C
68 Toro 455 Oil Drip Pan
68 Toro 455 Push Rods
68 Toro A Brace (goes under front of car)
68 Toro A/C Blower Input Duct
68 Toro Air Cleaner Chrome Center
68 Toro Air Cleaner w/ light blue label
68 Toro Alternator - Delco Remy
68 Toro Assorted bolts, fasterns, screws (many labeled)
68 Toro Assorted Relays, reguators
68 Toro Assorted Vacuum Hoses (color coded)
68 Toro Backup Light Chromes
68 Toro Backup Light Lenses w/gaskets (rough)
68 Toro basic cigarette lighter bezel (black)
68 Toro Brake Drums (2)
68 Toro Brake Pedal
68 Toro C-Bracket (goes around headlamp door actuator)
68 Toro Chrome flasher switch knob (ex cond)
68 Toro Comfortron electro/vacuum switch tube (under dash)
68 Toro Condenser Core
68 Toro Courtesy Lamp
68 Toro Cruise Control Set Up
68 Toro CV Joint Bolts
68 Toro Dimmer Switch
68 Toro Dip Stick
68 Toro Door brushed chrome along top
68 Toro Door Hinges R&L
68 Toro door light lense red (2) (good cond)
68 Toro Door Pull (shell/strap) white
68 Toro Door Pull turquoise
68 Toro Driver Door Chrome switches
68 Toro Emergency Brake mechanism
68 Toro Emergency Brake Pedal
68 Toro Engine Belts (assorted)
68 Toro Fan Shroud (hole in bottom)
68 Toro Fender Toronado emblems (good cond)
68 Toro Firewall cable/tube pass-through (12 holes)
68 Toro Floor Heater Vent (ex cond)
68 Toro Front Bumper Braces
68 Toro Fuel Sending Access Cover
68 Toro glove Box
68 Toro Glove Box lock and latch (no key)
68 Toro Headlamp Switch (assume it works)
68 Toro Headlamp Switch knob (w/stem) (black)
68 Toro Headlight opening trim (rough)
68 Toro Heater Core
68 Toro Hood Bumpers (3)
68 Toro Horns
68 Toro HVAC Blower Motor
68 Toro HVAC ducts
68 Toro HVAC Plastic Defroster Ducts
68 Toro Inner Grill Left (ex cond)
68 Toro Inner Grill Right (ex cond)
68 Toro Inside Door handle (not sure which side)
68 Toro Interior Driver Side rear side panel (turquoise) (fair cond)
68 Toro Lower Center Dash Piece - Turquoise
68 Toro Opera Light Lenses (no cracks, yellowed) (2)
68 Toro Package Shelf (turquoise)
68 Toro Parking Lamp Lenses (3) some cracks
68 Toro Passenger door chrome and switches
68 Toro Passenger side vacuum lock
68 Toro Perfect Circle Cruise Control
68 Toro Power Antenna Switch
68 Toro Power Antenna w/wire harness
68 Toro Power Seat Machine
68 Toro Power Seat Switch
68 Toro Radiator
68 Toro Radio knob bezels (chrome & black) (ex cond)
68 Toro Rear Driver side Ash Tray with Lighter (litle rough)
68 Toro Rear Passenger Ash Tray with Lighter (little rough)
68 Toro Rear Quarter window Left
68 Toro Rear Quarter window motor and gears Left
68 Toro Rear Quarter window motor and gears Right
68 Toro Rear Quarter window Right
68 Toro remote control mirror control bezel
68 Toro Reserve Vacuum
68 Toro Rocket Emblem 1 - 68 Toronado Front (rough)
68 Toro Rocket Emblem 3 - Thin - not sure of application (gas door?) (great cond)
68 Toro Starter
68 Toro Steering column access lid
68 Toro Tilt Stem - chrome chipped
68 Toro Transmission Cooler Line (tight u-shape)
68 Toro Trim top of fender LH (~4" long)
68 Toro Turn Signal Stem - chrome chipped
68 Toro Vacuum (Coffee Can)
68 Toro Vacuum Canister
68 Toro Vacuum Switch (diaphragm patched)
68 Toro Vacuum Switch (good diaphragm)
68 Toro Vacuum Ts and other misc
68 Toro Vacuum Valve for Headlights
68 Toro Valve Stem NOS (2)
68 Toro Vapor Barriers
68 Toro Wheel Well Trim Left (good cond)
68 Toro Wheel Well Trim Right (good cond)
68 Toro Window Switches (rear)
68 Toro Windshield Chrome Trim (bottom)
68 Toro Windshield Washer Pump
68 Toro Wiring Harness (color coded, connectors, etc.)
68 Toro WW washer reservoir (good cond)
68 Toro WW washer reservoir (patched)
6x Olds cigarette lighter (fancy metal knob)
6x Olds cigarette lighter (fancy metal knob) (great cond)
6x Olds cigarette lighter socket & bezel (silver)
6x Olds Door Lock knob bezel (chrome)
6x Olds Door Lock knobs (chrome) (great cond)
6x Olds Headlamp Switch knob (w/stem) (metal)
6x Olds radio knobs (silver metal) (3) (great cond)
6x Olds Rocket Emblem 2 - Thick - not sure of application (good cond)
6x Olds windshield washer knob & bezeal (metal)
Things I have but haven't located yet
68 Olds Fisher Body Manual (good cond)
68 Olds Shop Manual (some Toro pages removed to binder)
68 Toro Accelerator Cable
68 Toro Accelerator Cable & Kick Down Switch
68 Toro Headlight Doors (rough)
68 Toro Headlight trim rings
68 Toro Heat Actuated Vacuum Valve (not sure if of value)
68 Toro Hood Wire push-up Springs
68 Toro Neutral Safety Switch
68 Toro Seat Back Release Buttons
68 Toro Shift Linkage
68 Toro Speedometer Cable
68 Toro Weather Strip (?)
68 Toronado Parts OKC
Re: 68 Toronado Parts OKC
If you have questions about any of the parts you can also call me at 405-204-9097.
Thanks,
John
Thanks,
John
vegastoro68
- Years Owned: i own a 1968 Toronado
I just saw your post and I was wandering do you still have any of the items listed for sale?
Yes, I have all of it - buyer take all.
PayPal or Personal Check in full to reserve it.
toro68
- TOA Membership Number: 102
Any 68/69 valance panels? Plastic sheilds/filler that go around the headlights and in back of the front bumper?
Yes, they have some rub marks and some cracks. Definitely not show quality. If I were to use them, I'd try to use some good glue and paint to bring them back to an original look.
- 100_1078.JPG (42.4 KiB) Viewed 37374 times
Do you have these molding strips located above the front bumper?
And are you able to provide photos of the "headlight surrounds" please?
Thank you.
Thank you.
- DB-Damaged Molding - 1.JPG (180.41 KiB) Viewed 37366 times
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
Do not have the rubber strip. Here are two photos of the headlight surrounds. I'll post the other two in the next post.
- 100_2601a.jpg (67.03 KiB) Viewed 37364 times
- 100_2598a.jpg (54.75 KiB) Viewed 37364 times
Here are the other two headlamp surrounds.
- 100_2600a.jpg (61.63 KiB) Viewed 37364 times
- 100_2599a.jpg (249.34 KiB) Viewed 37364 times
I like this one because it still has all 4 tabs:
Please tell me your price for just that one.
There's another item(s) I also need. The photo below shows the rusty bucket that headlamps fit into. I've got all 4, but some don't have the adjustment screws needed to aim the headlight. How many screws can you sell me?
Thank you.
Thank you.
- ToroHeadliteBucket.jpg (88.31 KiB) Viewed 37360 times
- ToroAimingBolt.jpg (80.47 KiB) Viewed 37360 times
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
