Hello from Germany!
Re: Hello from Germany!
Postby Otto Skorzeny » Sun Jan 14, 2018 11:23 am
Automatic trunk lid release. Does it work?
Jelonek
Years Owned: 1
Postby Jelonek » Sun Jan 14, 2018 11:50 am
no Otto it work´s very good
Jelonek
Years Owned: 1
Postby Jelonek » Sun Jan 14, 2018 12:02 pm
how can i change oil in differential ? one screw to put it in i found but where is the screw to drain it???
sorry but i have a lot of questions...
-how can i take of the wonderfull clock? everything must be put down?
- how can i take of the musicspeaker on ther backseat? from insite or from trunk...
Postby Otto Skorzeny » Sun Jan 14, 2018 1:15 pm
Olds manual says that periodic or seasonal changes of differential fluid are not recommended.
Unless you believe yours to be contaminated or something, I'd leave it alone. Use a suction pump to remove it if you have to.
Jelonek
Years Owned: 1
Postby Jelonek » Sun Jan 14, 2018 1:34 pm
:roll: ok thanks
Jelonek
Years Owned: 1
Postby Jelonek » Sat Jan 20, 2018 8:01 am
now i try to solve a problem with back- and safty-neutral....lights, i found this part in bad condition :idea: swith...GM Part # 392370 see foto
question: what is inside between the plate and plastik ...i think a small contact-matallplate ? :?:
thanks for help!
Jelonek
Years Owned: 1
Postby Jelonek » Sun Jan 21, 2018 11:25 am
:mrgreen:
Jelonek
Years Owned: 1
Postby Jelonek » Sun Jan 21, 2018 11:26 am
ups... the first ist the last ....
i rescue thios part.... 8-)
Postby Otto Skorzeny » Sun Jan 21, 2018 5:48 pm
Looking at it the first time I figured a spring was supposed to be in there. I've never had one apart so I didn't know for sure. Good work Jelonik.
Jelonek
Years Owned: 1
Postby Jelonek » Tue Jan 23, 2018 1:53 pm
so the next one ... lamps, in EU we have another one ... see the picture,
what is the difference ? and why ? :?:
upper lights from US,
in the kitchen :) new lights
