Yet Another Disc Brake Question
Chazzer
TOA Membership Number: 146
Postby Chazzer » Sun Jan 08, 2012 10:21 am
Hey Toro Guru's,
Would any of you know if I can keep my drum brake adjustment valve as seen below?
I have fit tested my 69 disc brake booster, master and metering valve combo. All the brake lines line up perfect. They both use the same distribution block.
Cheers, Jim
TOA# 146
Chazzer
Re: Yet Another Disc Brake Question
Postby Chazzer » Sun Jan 08, 2012 10:26 am
Here is a pix of the 68 drum brake set up
Cheers, Jim
TOA# 146
Chazzer
Postby Chazzer » Sun Jan 08, 2012 10:30 am
Here is the 69 disc set up. Notice how all the brake lines all line up. If i can keep the drum brake adjustment valve. I'm pretty much set.
Cheers, Jim
TOA# 146
Chazzer
Postby Chazzer » Sun Jan 08, 2012 10:47 am
Does anyone know what the difference is between the drum brake booster and the disc?
The only difference I have determined so far is the eyelet that hooks to the brake petal has a slightly smaller diameter on the 69 disc booster.
Cheers, Jim
TOA# 146
xgecko
TOA Membership Number: 831
Postby xgecko » Sun Jan 08, 2012 3:46 pm
I am not completely certain but it seems reasonable to think that the boosters are pretty much the same. As for the rear adjustment valve I am pretty certain you will need to use the version for disk brakes as there is a difference in the proportioning between drum and disk front brakes.
I did not do a drum to disk conversion so it is not my area of expertise, my comments come from a general knowledge of how braking systems work. Specifics may vary from situation to situation, so it would be wise to mimic the disk brake setup when you convert; that means the valve probably needs to be replaced with whatever is on the disk brake setup.
Chazzer
Postby Chazzer » Mon Jan 09, 2012 6:03 am
Thanks for your input X.
I thought there could be a difference from drum to disk. However I cannot seem to find any markings or stampings on the valve. Which makes one wonder: how in the heck could they keep things straight during assembly!
Cheers, Jim
TOA# 146
