Hello all,
The Fuel Gauge in my '66 Toro is pegged at full.
I removed the liner from the trunk and, behold, rusty crap all over the top of the tank where the sending unit is. The wiring post looks just as bad.
I need a new trunk pan but I'm leaning towards finding a new tank and sending unit to be on the safe side.
Any avenues to get the Tank and Sending Unit mainly...? Trunk pan would be nice also...
Thanks in advance,
Adam
Help needed: Fuel gauge pegged at FULL
pudland
- TOA Membership Number: 987
____________
TOA# 987
TOA# 987
Re: Help needed: Fuel gauge pegged at FULL
I don't believe you can buy a new tank anywhere... IIRC... the same goes for the sending unit.
I've seen sites/people who offer to rebuild your original one, but mine works perfectly, so I never kept any tabs on such things...
My tank had a small hole in it, I got POR-15 fuel tank sealer and used that, then, for extra measure, I coated the entire outside of the tank with POR-15 as well... It was something of a process, but it seems to have worked beautifully, and my tank will now be around, long after the rest of my car is red dust
The only tip I have on this if you do it... make sure you remove your tank sock before putting in the sealant... Not doing so was something of a PITA for me XD
- Eightballz
- TOA Membership Number: 826
fusick.com offersr sending units...afaik
pudland
Thanks for the feedback!
I'll page through fusick.com.....
I'll try the POR-15 as a precaution.
Thanks again,
Adam
Thanks again,
Adam
____________
TOA# 987
TOA# 987
pudland
Eightballz:
I went through Cat# 22BC 5.00 and didn't see any sending units...
Was it in a different catalog????
Thanks,
Adam
Thanks,
Adam
____________
TOA# 987
TOA# 987
- Eightballz
damn..i'm sorry.
it was www.usapartssupply.com
you can purchase a rebuilt unit...199$ and 75$ core deposit
browse the catalog ..page 32
http://www.usapartssupply.com/uploads/U ... atalog.pdf
pudland
Eightballz:
Found it...
Now I'm going to page through the rest of the catalog!!!!
Thanks,
Adam
Found it...
Thanks,
Adam
____________
TOA# 987
TOA# 987
pudland
FYI
Spoke with usa parts supply.....
He said if its a canister style sending unit, which he believes it is, I have to ship it to them so it can be "converted" for approx $300...
Does this sound right to anyone??
Adam
Adam
____________
TOA# 987
TOA# 987
Been there, done that, killed the car (threw a rod!) two weeks after putting the rebuilt fuel sender in...
So I recommend using these folks for a rebuild. They did mine very nicely for $149.
http://www.fuelsender.com/contact.html
pudland
xgecko:
How does a rebuilt fuel sender throw a rod????
Thanks for the link... I'll check them out!
Adam
Adam
____________
TOA# 987
TOA# 987
