MMOEXP: There plenty of tools available in Madden 25
Use this forum for test posts and to see how this forum works.
Ludwighench
Postby Ludwighench » Fri Jan 03, 2025 12:23 am
Look at the defense that is considered to be cover 1. The cover 1 defense consists of only one player in a deep downfield. The reason why cover 1 defenses are utilized isn't just because it provides a protection over the top and we're also capable of using an additional defense to speed up or provide with Madden 25 coins cover when needed.
The main reason for using the cover-0 defense is usually to get the quarterback in the game in the quickest time possible. There's no way to help for if you or one of your Cornerbacks is beaten, so making sure you put pressure immediately on your opponent is crucial. The Cover 0 defenses aren't used as often due to the risk being far too high in comparison to the benefits.
The Cover3 defense is very popular, but especially when playing in a zone. A lot of Madden players prefer to switch on this defense Quarters 3 Deep: 3 Deep Man when they've forced their opponent into a third long scenario. The reason why this defense is a great option in this particular scenario is that the entire offensive team is fully manned and there's plenty of support to the top. Cover 3 is typically sufficient to block a deep pass wherever in the field.
Cover 2 zones can be more risky than cover two man defenses since once the receivers have crossed their cornerback's flat areas, they will face a one-on one match against the Safeties that tends to favor the receiver. If the defense was a man defense the Cornerbacks could have been present downfield. A majority of people opt to two zone defenses to cover when their opponents are within the 10-15 yards. A shorter field is what is a challenge to beat by players.
Fighting against a fast-moving quarterback is always one of the toughest tasks in cheap Mut 25 coins. There plenty of tools available in Madden 25 to deter players with an attitude of running first within the pocket. The first step is to place defensive ends inside QB's contain assignments using hot routes or a play-call. Third, you can call blitzes on outward (corners or nickel backs). Thirdly, there should be defenders on the flats to attack on the run out. Additionally, you can include a defender in QB watch the quarterback.
Re: MMOEXP: There plenty of tools available in Madden 25
Postby xeror » Thu Jul 31, 2025 1:56 am
Postby xeror » Thu Jul 31, 2025 2:06 am
Return to “Test Forum”
