Promised engine out, engine in, pictures
Swiss toronado 1973
Years Owned: 1973
Postby Swiss toronado 1973 » Thu Mar 30, 2023 10:50 am
Hello everyone
As promised, I want to show you some pictures of my 1973 Toronado during the oil pan gasket replacement.
For this work you would have to take out the whole engine. During this work, my mechanic renewed, lubricated or treated with rust converter various other things. After 50 years, the seals of the oil pan were as hard as a stone and would have to be removed with a lye :?.
During this work he found 2 loose screws on the drive shaft :o . It's a miracle they didn't fall out. At the same time he also had to replace the servo pump because it was no longer tight.In parallel with these works, he has set both windows correctly. It was very difficult to close the door and it was also difficult to close the windows properly. We had all door, window and trunk seals changed last year 8-).
Now let you enjoy the photos. For questions, just let me know.
It's all dry now. No more oil or other liquid loss. The work has paid off. ;)
Whenever I try to upload a picture I get this message. The photos are about 1.5mb in size.
What can I do?
[b]Image file type mismatch: Expected extension png, but specified extension jpg.[/b]
roland
TOA Membership Number: 860
Re: Promised engine out, engine in, pictures
Postby roland » Thu Mar 30, 2023 9:35 pm
Go to https://picr.de/ for proper forum pictures. Copy/past your pics in your acount there and take the complete img code for your post then. No pic would ever lost.
Roland TOA#860
Swiss toronado 1973
Years Owned: 1973
Postby Swiss toronado 1973 » Fri Mar 31, 2023 10:17 am
Swiss toronado 1973
Years Owned: 1973
Postby Swiss toronado 1973 » Fri Mar 31, 2023 10:22 am
Thank you Roland. :D
Swiss toronado 1973
Years Owned: 1973
Postby Swiss toronado 1973 » Fri Mar 31, 2023 10:29 am
Unfortunately I didn't get the right order but the experienced users will already know what the next step was 8-)
roland
Postby roland » Sat Apr 01, 2023 4:19 am
Do you or your mechanic changed the old timing chain into a new and cleaned the oil pump? If the timing chain set was never changed before it is more than possible that it is worn out and lengthened. :?:
Roland TOA#860
Swiss toronado 1973
Years Owned: 1973
Postby Swiss toronado 1973 » Sat Apr 01, 2023 11:34 am
oil pump was renewed, timing chain I don't know. But the mechanic seen that something has always been done with this car and everything that has been done, has been done well, he says.
I am confident :)
Postby Otto Skorzeny » Sun Apr 09, 2023 5:51 am
With engine out a lot of things can be done that are much easier than when the engine is in the car.
Clean and paint the engine and even the engine bay if necessary. If the timing chain is still the nylon tooth style, replace it with the all steel one.
DoylePadilla
Years Owned: I would like to own a car at least from 2016
Postby DoylePadilla » Tue Apr 11, 2023 1:55 am
Excellent condition, amazing, so many years have passed. the car is older than me and looks much better than me)
Swiss toronado 1973
Years Owned: 1973
Postby Swiss toronado 1973 » Tue Apr 11, 2023 11:10 am
who knows, maybe he'll outlive us all. :lol:
I'll definitely do my best to make sure he's okay 8-)
