Where can you distinguish date codes on Toronado Engines, to understand if your 1968 Toronado engine is original or might be a 1969 or 1970 engine if the VIN no longer exists on the block?
Thanks,
ToronadoMike
- Years Owned: 1968
- 762
- TOA Membership Number: 895
- Years Owned: 1966 Oldsmobile Toronado owned for 2 yr
Re: Where can you distinguish date codes on Toronado Engines
The color of the engine block may help you narrow it down.
1966 and 1967 Toronado units were light blue
1968 Toronado's were painted metallic blue
1970-1976 versions were metallic blue at first, then nonmetallic blue.
If it's red, then it's not an original Toronado Engine.
