1967 Toronado Strato Bucket seat codes
Postby Doc Hubler » Tue Oct 15, 2013 6:18 pm
I stripped all the old upholstery off my 67 Toro seats as they had to be redone. Here is the correct code that was written on all the seats (under all the upholstery). I don't know what the "H" stands for. Any help? The code "090" is fits with the car that I have which has the strato bucket seats.
Strato Bucket Seats (Option A51)
TRIM CODE/COLOR
090 Black Morocceen and Pattern Cloth
I will probably look to see if SMS has the correct fabrics; other suggestions are appreciated!
Toro Seats Code.jpg (23.63 KiB) Viewed 6013 times
69W34
Re: 1967 Toronado Strato Bucket seat codes
Postby 69W34 » Tue Oct 15, 2013 7:11 pm
Doc the 'H' could be anything even an in house code, that said you should have cloth center inserts, though the seat side bolstered should be vinyl if you have buckets, the bench seat bolster were cloth. The white seats were all vinyl as was the red/garnet the turquoise, blue and plum seem to be cloth only inserts and bolster.
Getting back to the black everything I am seeing in the database is cloth with one exception, though the stitching on it is not quite right so I'm a bit skeptical as to what it was originally.
Postby Doc Hubler » Wed Oct 16, 2013 7:39 pm
Bill,
Sorry, these were black cloth centers with black vinyl bolsters. Actually, that's what the 090 codes says it should be. Don't know what "H" is for though. Anyway, we rarely get to see the markings on the seats, so thought I'd post them.
