fender emblem removal
I need to remove the toronado and front wheel drive emblems so i can sand my fenders, does anyone know if i can remove them without taking the fenders off?
Shane A
TOA#340
1970 Toronado GT
TOA#340
1970 Toronado GT
waterzap
- TOA Membership Number: 1058
- 1978 Eldorado
Re: fender emblem removal
The little things that say Toronado?
Held on by little pins and screws on the inside.
- 762
- TOA Membership Number: 895
- Years Owned: 1966 Oldsmobile Toronado owned for 2 yr
I don't think you'll be able to remove the scripts without removing the fender.
Here are a couple of links that may help.
1966 Fisher Body Service Manual (see section 12, Exterior Moldings)
http://www.oldcarmanualproject.com/manu ... index.html
1966 Oldsmobile Chassis Service Manual (see section 11, Sheet Metal)
http://oldcarmanualproject.com/manuals/ ... index.html
These are not Toronado specific, but GM in general. Still, it may give you some insight into how they are attached and how best to remove them.
Hope that helps
Hope that helps
hbarbee
- TOA Membership Number: 1035
- Years Owned: 1969
You cannot remove them "properly" without removing the fender. However, you can carefully pry them off. The studs and associated nuts will break off and stay behind the finder. You can then grind it flat and epoxy new studs to the emblems and re-install them. I used nails with flat thin heads and a diameter that just slides into the holes, grind and trim them appropriately. You can then use a thin coating of epoxy on the nail studs to hold them in place.
HBARBEE 1969
I was afraid that I would have to remove the fenders, didn't want to but I guess I will anyway because it sound like the best option.
Shane A
TOA#340
1970 Toronado GT
TOA#340
1970 Toronado GT
U.co.uk/Activate is the online portal to easily activate your U account or card and start managing your services online.
Visit U.co.uk/Activate to quickly set up and activate your U account for secure access to all your online features.
Menards.capitalone.com/activate is the online site to activate your Menards Big Card from Capital One securely online.
Visit Menards.capitalone.com/activate to quickly enable your new Menards Capital One credit card for use.
Easily activate your Menards Big Card by logging in at Menards.capitalone.com/activate.
Menards.capitalone.com/activate helps you get your Menards Capital One card ready for shopping and rewards.
Activate your Menards Capital One credit card online in minutes through Menards.capitalone.com/activate.
Visit discover.com/activate to quickly activate your Discover credit or debit card online.
Easily activate your new Discover card by following the secure steps at discover.com/activate.
discover.com/activate helps you enable your new Discover card for instant use.
Activate your Discover credit card safely and start managing your account at discover.com/activate.
Go to discover.com/activate to verify and activate your new Discover card in minutes.
Secure sign-in portal for accessing your Syw.accountonline.com login account and personal settings.
Quick login page to manage bills, statements, and account preferences on Syw.accountonline.com login
Centralized access point by Syw.accountonline.com login login for users to view transactions and update contact details securely.
Syw.accountonline.com login is User-friendly gateway to check account activity and download documents after signing in.
Single place to sign in, reset forgotten passwords, and protect your syw.accountonline.com Login profile.
Mobile-ready login interface for fast access to your syw.accountonline.com Login services on the go.
syw.accountonline.com Login is Encrypted sign-in entry that connects you to account tools, notifications, and support options.
