Winter upgrades on the list...
Re: Winter upgrades on the list...
Postby xgecko » Mon Nov 14, 2011 7:05 am
Had a feeling you would say that. I'll take that into consideration when I redo it so as to see if I can help you out. Basically what it will consist of is a circuit that runs from the fan side of the fan relay to an indicator on the dash to show normal operation then another circuit from a switch on the dash to a seperate relay in parallel with the fan controller relay. If the light goes out you flip the switch and it will provide power to the fans. The hardest part of it all is making it look good and running the wires - I copped out on this part for my initial install but hope to pretty it up this season when I convert to the HP ECU controller as part of my Fuel Injection upgrade.
68 Toro
TOA Membership Number: 99
Years Owned: 1968
Postby 68 Toro » Tue Nov 15, 2011 9:05 pm
Thank you that would be a great Christmas gift . . . for my Toronado!
Seriously, if you need a down payment for the purchase of materials, just let me know.
Oh yeah, my setup has two fans. It would be reassuring to see two green LEDs on the instrument panel, indicating that both fans are spinning (or at least power is being supplied to both fan motors). The parallel (bypass?) power switch to these fans, I would probably mount out of sight, underneath the instrument panel.
Dave B.
Miami, FL
TOA # 99
