Hello from Germany!
Jelonek
Years Owned: 1
Re: Hello from Germany!
Postby Jelonek » Sat Sep 05, 2020 3:31 am
Hello Guys
I replaced the outer CV joint boot in my Toronado last time and I wonder about the the copper-clamp - see the picture. There was any connection, any solderind, nothing etc. How they did it 50 years ago? I had to cut the clamp tu a new one.
outer CV joint boot replacement
Postby Otto Skorzeny » Sat Sep 05, 2020 4:53 am
I've never seen a copper clamp like that. My boots, one of which I replaced, had the normal steel band with a crimp in it.
Jelonek
Years Owned: 1
Postby Jelonek » Sat Sep 05, 2020 8:27 am
Yes this is a very strange and I asked a lot of mechanics , nobody known how it is made... :shock:
you can´t use a hot temperature couse of rubber, there is no method to do it another,
perhaps know somebody from GM how was it made ???
Postby Otto Skorzeny » Sat Sep 05, 2020 7:49 pm
I doubt that is a factory clamp. I'll ask some other car people and Olds people specifically, if they've ever seen a copper clamp like that
Loaded 68 W34
TOA Membership Number: 1442
Years Owned: 1968 w-34
1972 vista cruiser pro touring
1972 holiday coupe (442 clone)
1966 chevelle convertible
Postby Loaded 68 W34 » Sun Sep 06, 2020 5:32 pm
My 80K mile 68 toro still had those copper clamps on it when I got it. They are original. They work just like PEX plumbing crimp rings. The factory would have used a special crimping tool. I don't think there would be a way to reproduce them. I put steel straps on all 4 of my boots when I replaced them.
Postby Otto Skorzeny » Mon Sep 07, 2020 5:27 am
Wow! Pretty cool. I've never seen one like it but I've never owned another front wheel drive car before.
My car had steel bands with a crimp in them like the type of straps you see on pallets, etc. I guess the boots were probably replaced at one time. It had 135,000 miles on it when I got it.
Jelonek
Years Owned: 1
Postby Jelonek » Tue Sep 08, 2020 11:28 am
wow! thats really cool ! but ...PEX plumbing crimp rings, the special crimping tool has to have contact to all surface of crimp and there is no so many place to do it ???... very interesting :shock:
Postby Otto Skorzeny » Tue Sep 08, 2020 4:37 pm
Of course the entire drive train was assembled first and then had the body dropped on it. All of those axles would have been clamped up on an assembly line without the transaxle and spindles attached.
Jelonek
Years Owned: 1
Postby Jelonek » Tue Oct 06, 2020 11:03 am
....."Of course the entire drive train was assembled first and then had the body dropped on it".... yes... thats of course right! :oops:
so another question.. I would like to change or "repair" my rear leaf springs couse thay are really not good.
Does know somebody a good solution for this problem? where can I get a new ?
Ist that the same like in 1967-70 Cadillac Eldorado?
Thanks for the Help!
Postby Otto Skorzeny » Tue Oct 06, 2020 11:52 am
The original is a single leaf spring on each side. I'm pretty sure they aren't sold anymore. The replacements are a traditional stack of leaves.
If I were you, I would send the original single leaves to Eaton Detroit Springs to have them re-tensioned.
https://www.eatondetroitspring.com/
https://www.eatondetroitspring.com/db/e ... L+-+425cid
