Engine rebuild disaster
Re: Engine rebuild disaster
Postby xgecko » Sat Mar 17, 2012 7:05 am
This sounds like a classic Mondello service situation from what I read. In many cases, if nothing goes wrong, it is no problem dealing with Mondello. However, when something like this happens, caveat emptor.
While my experience has been good so far, I have observed hints of this kind of thing, so I am very wary now. I will only buy from Mondello when I feel they are the best source, if I can find alternatives I will use them.
Glad to hear you have improved your situation considerably!
pac66
Postby pac66 » Sun Jan 05, 2014 7:56 am
I just wanted to give all an update on the 66 Toronado engine. It has been a couple of years and the car now has some miles on it. By making my own metering disks and replacing the disks that came with the lifters that solves the oil issues. The engine runs great with no oil consumption, car is a blast to drive, and it turns a lot of heads on Cape Cod ( most people say they haven’t seen on in years). A year ago I purchased a 1937 Cord needing engine and transaxle work, that car is progressing. It has been fun to take them both out to shows and cruse nights as Cord is the last American front drive until the 66 Toronado came out.
69W34
Postby 69W34 » Sun Jan 05, 2014 4:20 pm
..... Wow, with one side overhead 1/2 full of oil that's some 3-4 qts. between the 2 side, 1 qt in the filter, factor in the oil gallery's to the mains then rod, not much left in the pan no wonder the oil light was coming on and trashing the lifters ta-boot in one easy lesson! .... after reading this I presume that the HV oil pump is still in place, yes? .....
I have never know any one that has had good luck with HV oil pump in street use with out having to go through contortions ironing out the after effects!
pac66
Postby pac66 » Sun Jan 05, 2014 5:42 pm
Fortunately the oil light only came on as I turned a corner into my home, but it did surprise me as gee it’s got a 6 quart system. Oil pump was and still is just a stock pump not a HV. If you ever saw 8 fountains of oil coming from the pushrods at idle you would have been amazed. The problem was all in the lifters with the wrong metering disks. I added to my original post in order to help any future rebuilders to check their new lifters before using them. Sure caused me a lot of wasted time and money.
69W34
Postby 69W34 » Sun Jan 05, 2014 7:10 pm
........you still get the light coming on it is indeed fascinating!
