FYI the brake pedal link is floppy and will drop down in the image but you will have no problem hooking it up to the brake pedal.
Good work on identifying multiple options. I do know that these will fit better if they do not have the accumulator; no exhaust mods will be needed. However, we will have to see if these units will in fact fit; by obtaining a used unit cheaply it might be possible to test before ordering. That was how I was able to determine that I needed a new master cylinder; I tested with the old one from my Eldo and once I knew it fit I went out and bought one.
Hydroboost Upgrade is well worth it
Re: Hydroboost Upgrade is well worth it
