Hello from Germany!
Jelonek
Years Owned: 1
Re: Hello from Germany!
Postby Jelonek » Sun May 06, 2018 5:45 am
so... today i finished the work.... and i´m very happy :D
heater core replacement ! how to do it :geek: Part1
you can everything do from engine site and without to put down the hood!!!
for small and older people: you need after that a medicine against a backpain! and musclepain :mrgreen: or better before the work :lol:
the aircondition and heater has a constraction of two parts, it is necessary to put down only the left one ( left - driver site !!!) -
1) screw off everything from above the Heater box (cables and heater valve) , but not the small vacum! - see pics
2) crew off the 6 screws of box, nr. 5 and 6 from underneath - sorry... first you think it don´t work but it is easy and possible :)
3) take of a box to the left site
crews, nr 5 und 6 are a small "problem"
aircondition rechts and heater part left
Jelonek
Years Owned: 1
Postby Jelonek » Sun May 06, 2018 5:50 am
everything put down from the box...
first carefully!!! rubber - my was in a very good condition and i use it again
then 4 small screws,
then small vacum regulater - mark the crew position!!! then flap at the front,
and than you can see your problem :ugeek:
put it down everything
make a mark for the screws!
Jelonek
Years Owned: 1
Postby Jelonek » Sun May 06, 2018 5:54 am
4 small screws at the front and rear of heater :D :D and put down the broken heater
than everithing clean
and put everithing togather again :arrow:
rubber for the windows :) as a seal
clean and liitle bit spray
Jelonek
Years Owned: 1
Postby Jelonek » Sun May 06, 2018 5:57 am
I put a little bit sikaflex rubber on the ald rubber.. and to the switch space (?) to the aircondition box ( i hope you anderstand me :)
sikaflex-rubber
sikaflex-rubber
Jelonek
Years Owned: 1
Postby Jelonek » Sun May 06, 2018 6:06 am
and put everything together in to the car .... the best are two people for the first 5 min. for the first fixation (wife, friends, dog...everybody)
from the left site, at first 2 screws upper for the first fixation.... than from under und than left seit .... but you can do like you want ..... :lol:
the rest is easy .....
if you have a question ... please let me know !!! 8-)
good luck and don´t forget a medicine !!! cause of backpain :twisted:
Postby Otto Skorzeny » Sun May 06, 2018 6:16 am
That does look pretty easy. I'll have to do mine before next winter.
Is the Sikaflex a silicone type sealer like the type used on bath tubs and sinks?
Jelonek
Years Owned: 1
Postby Jelonek » Sun May 06, 2018 11:30 am
that with sikaflex and silikon :shock: i will check .....
Jelonek
Years Owned: 1
Postby Jelonek » Sun May 06, 2018 1:01 pm
sikaflex 521 uv is not a silikon... only a fluid-rubber, very stable and elastic, i use it in a home, car, everywhere, last time i repair with it my cv-rubber boots and it works perfect (i didn´t believe it... :lol: )....
Postby Otto Skorzeny » Sun May 06, 2018 5:25 pm
Interesting. I wonder if it's available here in the USA?
Yes it is.
It's $30 + on Amazon and ebay for a 10 oz tube.
Mikel
TOA Membership Number: 100
Postby Mikel » Mon May 07, 2018 5:59 pm
Fantastic photos! Were you able to remove the A/C / heater box with the fenders on?
