1966 Toronado Parts Car
Re: 1966 Toronado Parts Car
Postby Doc Hubler » Mon Nov 16, 2015 12:46 pm
Sure, I can cut you a pair. I used nylon reinforced rubber of the same thickness as the originals. I take it you know exactly where this attach.
Postby Otto Skorzeny » Mon Nov 16, 2015 1:55 pm
I have an idea were they go but have never seen any in person. (In fact, my Toronado is the first one I've seen in person in a decade or so. I have yet to see another.)
Since I've seen pictures of them on other cars, I imagine I could figure it out just by looking for screw holes that match up with the pattern.
If you would post pictures of them on your car, that would be great.
Are they about 1/4" thick or so?
brian66toro
Postby brian66toro » Mon Aug 22, 2016 5:30 am
Looking for a set of seat track covers.
Thanks,
Brian rachlin@comcast.net
Postby Doc Hubler » Thu Aug 25, 2016 4:06 pm
I don't know if there's anything left of this car. I am looking for a couple of items. One is a good brake pedal. The rubber is fine on mine, but the stainless part is worn through. As far as I'm aware, these are not reproduced.
Also, if this car happens to be equipped with cruise control, I need a new cutoff switch that shuts off CC when teh brake pedal is used.
chasgould
Postby chasgould » Thu Nov 26, 2020 9:02 am
Do you have a bottom front bench seat cushion in black vinyl or leather? I can come and pick it up so that it does not need to be shipped.
Thank you,
Charles
chasgould@mac.com
617-721-9400
Return to “For Sale: Parts”
