1966 Toro Exhaust system
paxtonshelby1966
1966 Mustang
2014 Mustang GT
Re: 1966 Toro Exhaust system
Thanks for the info. The muffler that I took of my car was shot - as was the whole system - but it was actually round. It seemed like there was a fair amount of room around the muffler when I removed it. I'm not concerned with originality as I am with it fitting well and sounding nice. I have decided to hold off on the exhaust until I pull the motor and figure out exactly what my build is going to cost.
- image.png (1.46 MiB) Viewed 19249 times
Yes, mine is original and it's round, too. The factory service manual shows a diagram and it is round.
Save all those pipes, of course, to be used as templates for the local exhaust system craftsman.
I just went out and crawled under my car to verify that the muffler is round and not a fat oval. It's round. The photo of the muffler from Classic that you posted does look fatter and shorter than the one you pulled off your car. Maybe it's just the angle of the photo but it sure looks larger in diameter than mine and the one you removed from your car.
I purchased my exhaust from these guys:
http://waldronexhaust.com/
The only issue I had was that the bends are not optimized and I had to have a local shop adjust the exhaust. This can be avoided by having a shop install the exhaust in the first place. If someone can get their car over to Waldron's they will perfect the bends and we would have a source for a high quality exhaust in either aluminized or stainless.
I should point out that they stood behind their product and sent me an entire replacement piece when it was obvious the bend did not work. I highly recommend them on this basis alone, it is hard to find folks that will provide this level of service.
Willysnut1959
Where can I buy the dual inlet / dual outlet muffler for my '66?
Marty, St. Louis, MO
Willysnut1959
Need the dimensions of an original muffler for a '66. Length of muffler body, muffler diameter, inlet/outlet diameters.
is cialis generic yet
loteprednol cytotec price in philippines Look, people fight and they don t like each other, and that s fine <a href=http://cialis.lat/discover-the-best-prices-for-cialis>can i buy cialis online</a>
