hey guys,
last night i was looking at some dashboards from 1st gen toros...
my 1970 toro only has these idiot lights but a 1966 toro has real gauges for water temp and battery.
do you guys think that it is possible to put that water temp gauge in my 1970 toro?
i guess i need to change at least the temp sending unit(s)? what about the wiring? you can see that the 1970 panel has 7 connector pins while the 1966 panel only has 6.
here are the panels:
http://www.ebay.com/itm/1970-Oldsmobile-Toronado-Gauge-Cluster-with-Bezel-and-Switches-lights-wiper-/271022538989?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f1a33c0ed
http://www.ebay.com/itm/1966-Oldsmobile-Olds-Toronado-Dash-Cluster-67-Instrument-panel-/130751364445?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AToronado&hash=item1e71637d5d&vxp=mtr
convert 1970 toronado idiot lights to 1966 toronado gauge??
- Eightballz
- TOA Membership Number: 826
- 68RocketAction
- TOA Membership Number: 1063
- Years Owned: 1968 - Oldsmobile - Toronado - Color: Ocean Turquoise Metallic - Interior: Turquoise
1983 - Oldsmobile - Toronado - Color: White - Interior: Blue - Location: Tulsa, Oklahoma
Re: convert 1970 toronado idiot lights to 1966 toronado gaug
Eightballz wrote:hey guys,
I have wondered this myself. I seriously hate idiot lights. I have been extremely tempted to just buy a gauge cluster from a 1966 or 1967 to see if it would work. However, I would seriously hate to go to the trouble of removing my instrument panel, moving over my speedometer, hooking it back up, and it not work...
That entire dropping the steering column and removing the drivers side portion of the dash is a serious pain. Although that is the only way to get access to everything...
bluecab
I have planned to do this on my '66; there are gauges on one side and the other side has the fuel gage and an idiot light.
If you look at the circuit boards for the gauges they will fit on either side so with some creative wiring and fab work this can be made to work.
In the case of a later car with only idiot lights you will need the gauge parts from 2 early cars, probably the hardest thing to find..
This will require changing both the engine and interior dash wiring harness ... or ... at the very least screwing around with the 70 harness to accommodate the 66 temp /oil sending unit comparable with gauges for temp /oil. As one (sending unit for gauges) will not work with (lights) and vice-verse in-addition the 68-70 used the two lights for engine temp 'Hot' and 'STOP engine'. The hot was a hot water switch and stop engine was driven by a sending unit attached to head bolt on the driver side and when that sucker lit up you better shut it off.
The wire of the plugins that drive the gauges and light on the 66-7 might /could very well be in a different position on the 70 plugins this is not something for the novist, it might be possible .... but ... do the home work or risk seriously screwing something up.
Also and Lastly the gauge cluster housings might simply swap out the only way to know would be to put them side by side on the bench. I would also highly recommend studying both wiring diagrams in detail .... miss anything and could very well could be screwed!
Re: convert 1970 toronado idiot lights to 1966 toronado gauge??
Lowes.syf.com/activate is the secure Synchrony Bank web portal used to activate and register your MyLowe’s (Lowe’s) credit/rewards card online.
Activate your Lowe’s SYF account at Lowes.syf.com/activate to quickly link and manage your services.
Lowes.syf.com/activate — a simple webpage to link and activate Syfy access on your TV or streaming device so you can start watching.
JCP.SYF.com/Activate is the secure Synchrony Financial web portal where JCPenney cardholders can quickly activate a new card or register/manage their account online.
A quick online portal to securely activate your jcp.syf.com/activate and set up account access in minutes.
Fast, step-by-step activation page for jcp.syf.com/activate Synchrony-issued card so you can start using your card right away.
capitalone.com/activate is the online webpage to activate your new Capital One credit or debit card securely.
Visit capitalone.com/activate to quickly enable your Capital One card and start using it right away.
The capitalone.com/activate activation page helps customers verify and activate their new cards online with ease.
capitalone.com/activate provides a simple way to confirm your identity and activate your new Capital One card.
Use Capitalone.com/activate to set up and unlock your Capital One card for online and in-store purchases.
Capitalone.com/activate allows you to get your Capital One card ready for use in just a few minutes.
Activate your new Capital One credit or debit card safely online at Capitalone.com/activate.
capitalone.com/activate.com offers an easy, step-by-step card activation process for Capital One customers.
Go to capitalone.com/activate.com to link and activate your new Capital One card with your account.
The capitalone.com/activate.com site helps you start using your new card after a quick online verification.
capitalone.com/activate.com ensures your new Capital One card is activated securely and ready for transactions.
Visit capitalone.com/activate.com to complete the activation of your Capital One credit or debit card in seconds.
The online portal at capitalone.com/activate.com helps customers quickly verify and activate new Capital One cards.
Simple and secure page to activate your new Capital one/activate credit or debit card online.
activate.uhc.com is the online website to activate your UnitedHealthcare member card online.
Visit activate.uhc.com to quickly enable your UnitedHealthcare health benefits card.
Use activate.uhc.com to start using your UnitedHealthcare plan benefits with easy online activation.
activate.uhc.com helps members securely activate their UnitedHealthcare UCard for healthcare services.
At activate.uhc.com, members can set up and activate their UnitedHealthcare cards in minutes.
