.[/quote]
Whoa, thats good news to me! Better than digging up 70's toro and re-scraping it. Could you post an item #, and issue of the catalogue so I can e-mail them about it? A scan of the page would be awesome too. This is something I wanted to do to my 66.[/quote]
I will post more info when I get back home this weeked...
carl
						66 Drum to Disc Conversion
- ride_there
- TOA Membership Number: 400
- Years Owned: 1966 Deluxe
- ride_there
Re: 66 Drum to Disc Conversion
For those that have asked:
The catalog is free from Kanter. I have to affiliation with them, I have ordered parts in the past though.
You can request a copy at: http://www.kanter.com/catalogrequestQAS.aspx
The issue sent to me is the fall 2010 issue. The new brake conversion kits are listed on page one.
kits include:
2 - 12" rotors
2 - single piston calipers
1 - set of pads
2 - caliper mounting brackets
2 - brake hoses
wheel bearing, seals, hardware
Master cylinder
power booster
proportioning valve
I am hoping someone will post experience with this kit in the future.
kits include:
2 - 12" rotors
1 - set of pads
2 - brake hoses
Master cylinder
power booster
proportioning valve
Hmm... well, that doesn't sound complete to me... it's missing the control-arm parts... unless the "Caliper mounting bracket" somehow adapts to the existing ones...
Thanks for the info, I'll let you know if I order it.. . will probably be a couple months though before I do....
Well, I just got my kanter catalogue... And i'm shocked! They say that with thier kit you can still use the factory drum wheels! I'll call and confirm this a bit later... But that makes this an optimum solution. Son't have to dig arround for wheels even, and live with the uglier (imo) disk-wheels.
				mikesteam
- Years Owned: 1966 olds toronado standard & 1966 olds toronado delux & 1983 olds toronado
hi i am new but saw the kanter cat. with the disc conversion for the 66 toro. Well I CALLED kanter and they said the don't know anything about it ! just wanted to check this out.
mikesteam wrote:hi i am new but saw the kanter cat. with the disc conversion for the 66 toro. Well I CALLED kanter and they said the don't know anything about it ! just wanted to check this out.
They made the kit through this winter, and discontinued them... They discontinued them a month after I had the money to afford one
 Oh well, I pieced together a set myself, so I'm all set to go. But, that's where the kanter kit stands for the time being.
 Oh well, I pieced together a set myself, so I'm all set to go. But, that's where the kanter kit stands for the time being.TOA #839
				mikesteam
thanks for the heads up on the kanter drum to disc kit - i think this winter i will do one of my 66s drum to disc. Brake Tech Solutions will do a 66 toronado  for about $1000.00 they claim they have done these cars before.
						how long do you have to take cialis before sex
If you take cholestyramine, colestipol, or sucralfate, ask your doctor or pharmacist how to take them with Urex Forte solution <a href=http://cialis.lat/discover-the-best-prices-for-cialis>best place to buy cialis online forum</a>
