Quadrajet trouble
Quadrajet trouble
Postby Twilight Fenrir » Mon May 30, 2011 6:27 pm
I'm rebuilding my Q-jet. It's not original to my toronado, but it is from a '66 olds 425. I'll get a new one from Sparky when I get my engine rebuilt. For now, I'm just getting it running.
Anywho, the issue I'm having is that my Dashpot piston & rod assembly were stuck. I believe this is why my car had no power, as the secondary throttle plates couldn't open witht he pot jammed in there.
In order to take the top of the carb off, I kinda had to pry at it and it disconnected the rod from the pot. After a little heat, and alot of patience, I managed to get the pot out of the main body. There's no rust... it was just... stuck.
I'm a little concerned about re-assembly of the unit. When I put the rod in, it only stays attatched if it's held at an angle. I suspect I could repair it by either squishing/bending the end of the rod. Or just using a nail and reproducing the rod, using the head to keep the pot on. But, I suspect that it's designed to come apart, or they would have made it so it would not....
I'm not even quite sure what this thing does!
Thoughts?
Thanks.
Re: Quadrajet trouble
Postby Twilight Fenrir » Mon May 30, 2011 8:05 pm
Oooooohhh... I may have found the answer... According to here:
http://carburetor-manual.com/rochester- ... -a-37.html
There is a rubber gasket at the end of the rod. No doubt I melted that off. Hopefully my rebuild kit came with a new one. Otherwise I should be able to get a tiny o-ring, or just a small piece of rubber and punch a hole in it to make a new one.
Would that be correct?
marinatuckson
Postby marinatuckson » Tue Jul 01, 2025 3:15 am
Use Amzon.com/redeem to add your gift card to your Amazon Wallet .
From amazon.com/redeem you can connect your Vizio Smart TV to the Internet, apps, and services like Google Assistant.
Enter the code and login to Amzon.com/code site to watch Prime Video on the device .
marinatuckson
Postby marinatuckson » Tue Jul 01, 2025 3:20 am
To play My5 TV channels and watch shows on your device, you need to first enter the code at my5.tv/activate.
my5.tv/activate lets you connect your Smart TV or streaming device to My5 and start streaming instantly.
To avail of the UK's free streaming service, you need to log in to my5.tv/activate.
marinatuckson
Postby marinatuckson » Tue Jul 01, 2025 3:36 am
You can activate your UHC health plan from the activate.uhc.com portal and avail medical benefits.
If you have taken a new health insurance then card activation and plan confirmation is done from activate.uhc.com.
activate.uhc.com allows users to view coverage, doctor network and claim status.
You can activate your health card very easily by filling some information on activate.uhc.com.
marinatuckson
Postby marinatuckson » Tue Jul 01, 2025 3:37 am
United Healthcare members can complete the activation process online using activate.uhc.com.
For new members, activate.uhc.com is a very helpful link that makes instant health insurance activation possible.
activate.uhc.com is a secure and quick service that helps you activate your health plan.
Before using the UHC card, visit activate.uhc.com and avail 24/7 activation and helpline facility.
marinatuckson
Postby marinatuckson » Tue Jul 01, 2025 3:40 am
Before watching TV, complete the first-time installation by visiting vizio.com/setup and configuring full settings.
vizio.com/setup gives users an easy setup process to enable all of the TV's smart features.
vizio.com/setup is a required step to install apps and download updates.
vizio.com/setupp is the official guide page where you can get complete information regarding TV installation.
marinatuckson
Postby marinatuckson » Tue Jul 01, 2025 3:41 am
With Bitdefender Central you can protect yourself from viruses and malware by managing online security across all your devices.
With Bitdefender Central you have full control over licenses, subscriptions and all security alerts.
Bitdefender Central is an extremely effective tool for setting up features like real-time scans and parental controls.
With Bitdefender Central, you can scan and track devices from anywhere.
marinatuckson
Postby marinatuckson » Tue Jul 01, 2025 3:44 am
For a faster and smoother streaming experience, it is necessary to visit netflix.com/tv2 and login.
netflix.com/tv2 is a special link used to sync the TV and account before watching HD quality shows.
marinatuckson
Postby marinatuckson » Tue Jul 01, 2025 3:50 am
Watch live sports and hit shows by visiting www.peacocktv.com tv and entering your activation code.
To unlock premium content, go to www.peacocktv.com tv and follow the activation steps shown.
Enjoy thousands of hours of entertainment after activating your account at www.peacocktv.com tv
