Repairing metal under windshield on '66
Posted: Thu Apr 28, 2011 10:29 am
Well, I've been working on this for awhile now, and after bouncing back and forth between weather it was possible or not, I went ahead and got started on it's repair.
I've got the new panel cut out, and am in the final process of cleaning up the metal to patch-panel adhesive it into place... And, I noticed something I hadn't before, so I want to check before putting it in and calling the glass guy...
Basically, the metal underneath the bottom of my windshield is almost completely rusted away. After looking it over, I made a flat template that seemed to make things work. However, while cleaning away the rust, I discovered that the part I'm replacing appears to have been atatched to the top of the firewall with spot-welding. And I'm questioning weather it was truely just a flat piece of metal, or if there is supposed to be a ledge. I thought the tables at the opposite ends held the glass in place.
So, basically, my question is: Is the metal under the windshield just smooth, or is there a ledge? It would really suck if I went through all this work and I can't use it... Here's some shots... (Sorry, they're kinda big)
Orriginal before work:
[/quote]
And, here's what I'm planning to do. I'm going to run 14 strips of 1/8" Steel across the gap, just thick enough to rest on the firewall, and catch under both the upper, and lower edge. After that, I'm going to patch-panel adhesive and rivet a piece of 22ga. steel ontop of it. Then grind, make pretty, and POR-15 the heck out of it. If there's supposed to be a ledge there though... I'm pretty much screwed. Unless I can just run some small bolts through the steel strips to catch the glass, but if the angle is way off.....
(The metal you see /is/ clean, I used an angle-grinder, so it's a little scorched. All rust has been removed from the bonding surfaces, and everything not being glued is already POR-15'd)
[/quote]
[/quote]And, here's what I'm planning to do. I'm going to run 14 strips of 1/8" Steel across the gap, just thick enough to rest on the firewall, and catch under both the upper, and lower edge. After that, I'm going to patch-panel adhesive and rivet a piece of 22ga. steel ontop of it. Then grind, make pretty, and POR-15 the heck out of it. If there's supposed to be a ledge there though... I'm pretty much screwed. Unless I can just run some small bolts through the steel strips to catch the glass, but if the angle is way off.....
[/quote]
[/url]
