				Is the front horizontal shock the same as the rear ones?
				Posted: Wed Aug 04, 2010 9:10 pm
				by Twilight Fenrir
				Well, pretty much the topic, is the horizontal shock absorber in the front-end the same as the two in the rear? Or is there a different model for that?
				Re: Is the front horizontal shock the same as the rear ones?
				Posted: Wed Aug 04, 2010 10:02 pm
				by 69W34
				I think you referring to the vertical front and rear shocks and they are different the horizontal shock are only used in front of the rear axle. Then I believe there are 2 styles of vertical rear shock on the 66, an (early) and a (late) the later style continued through 70
				Posted: Thu Aug 05, 2010 10:24 am
				by Twilight Fenrir
				69W34 wrote:I think you referring to the vertical front and rear shocks and they are different the horizontal shock are only used in front of the rear axle. Then I believe there are 2 styles of vertical rear shock on the 66, an (early) and a (late) the later style continued through 70
Naw, I was just looking through my service manual, there's a horizontal shock behind the steering mechanisms according to the book. MOunted right underneath the relay rod, near the PItman arm. Book calls it a "Steering linkage Shock absorber"
				Posted: Thu Aug 05, 2010 1:25 pm
				by 69W34
				Ooooo ...  the
steering damper
 Sorry  ....  yeah its all by its self and a one year application.
				Posted: Tue Feb 08, 2011 8:25 pm
				by Toronado66
				Twilight Fenrir wrote:Well, pretty much the topic, is the horizontal shock absorber in the front-end the same as the two in the rear? Or is there a different model for that?
No.
But still pretty easy to get.  I found mine on eBay.  Used on Cadillacs and a few other cars...
Darwin Falk
TOA#7
				Posted: Wed Feb 09, 2011 6:26 am
				by Twilight Fenrir
				Yup, I found one on autozone's website pretty cheep.
				steering damper
				Posted: Mon May 19, 2014 8:52 pm
				by 1977 Cutly
				I just got one off of Rock auto. How tough to install when it gets here?
