How to Verify Numbers Matching Car?
				Posted: Mon Oct 09, 2017 6:13 am
				by WaWaZat
				Hi guys, I posted this in the General Talk forum but perhaps not the right place to get attention;
http://toronado.org/forum/viewtopic.php?f=1&t=1975
				Re: How to Verify Numbers Matching Car?
				Posted: Tue Oct 10, 2017 10:31 am
				by GrantRees
				As I recall you need to look in three places.  I did this with my car, a '69.   VIN # is on the plate on the top of the dashboard driver's side visible through the windshield.   I'm wasting time at my desk at work so I can't remember if the full number is on the plate on the firewall, drivers side.   Motor serial # is stamped on a tab on the driver's side front of the motor.   It was covered by the bracket for the alternator as I recall.   I had the heads off (and the motor out of the car) so I can't recall whether it was on the head or the block but I'm thinking the block.   I had to wire brush and clean the area with a cue tip and solvent to get a read on the number.   The trans number is on the driver's side of the trans housing just behind the motor running vertically, again, as I recall.  I attach a picture of the trans no.   It not a good pic and hard to see the no, and the picture is rotated b/c I'm too dense to use the iphone correctly i guess.   that was hard to see as well but it's there.    I think what you're looking for is all the number after the "m" matching up.    I understand that there's a number stamped on the frame, pass. side about door area but I've not found that yet.
Cheers!
Grant
