'67 Running Extremely Rich
Posted: Thu Aug 28, 2014 8:30 am
Hi everyone, and I appreciate any advice in advance.
Have a '67, when I bought it we discovered someone had installed a carb for a 455 engine on it. I bought a brand new "4MV" carb. When received we took it apart, everything looked new, verified jets were proper and reassembled.
The reason we discovered the original carb was the wrong one was because it was running very rich. Now with the proper new carb, it is running even richer. I mean so rich that people get mad at me sitting behind me at a light, so rich I won't let my kids get near it while running. You get the picture.
We did the following troubleshooting:
- Verified all cylinders are firing.
- Checked vacuum, the engine is pulling 12-16 pounds, which is normal.
- Checked the timing, timing is correct.
- Plugs, wires and other ignition components are new and look good.
- Checked around the carb and gasket to ensure something isn't loose and drawing in air...nothing found.
We followed directions found online to calibrate the idle fuel/air ratio using the screws on the front of the carb, but this seems to have no effect at all. It seems like the carb isn't running on the "idle circuit."
We are completely baffled at this point. Has anyone been through this/have any ideas?
Thanks everyone for any help anyone might suggest.
Roy T
Roy T
