how to remove rocker moulding on a '66?
wal74
Postby wal74 » Fri Mar 07, 2014 4:43 pm
I'm removing all the trim on my '66 in preparation for painting the car. Can someone tell me how to remove the long rocker moulding without bending or breaking anything? I know there are some clips behind it, but does it just pop off, or do you pull up on the moulding or must you use a special tool? Also, in front and behind the door, the rocker moulding appears to be two pieces, or does it come off in one piece?
Dave
bluecab
Re: how to remove rocker moulding on a '66?
Postby bluecab » Fri Mar 14, 2014 3:14 pm
There are some small sheet metal screws with hex heads at the bottom edge. Once those are off the whole long trim will come off.
