transmission wiring '67 help please
Posted: Tue Nov 26, 2013 12:45 am
				Rodents ate much of the wiring and, while I do have a big orange 1967 manual, I'm not finding what I need.
Background: allegedly rebuilt transmission, did ~ 200 miles, then car parked 8-12 years. I removed/checked governor and vacuum modulator valve and they appear to be functional, although I have no benchmark other than what I've seen on the internet. Trans won't shift out of first gear. Makes no hint that it even wants to shift whether I manually select L and S or if I leave it in D up to about 35 mph. I've confirmed vacuum at the port on the carb and on the trans connection.
There is a black and a green wire, running as a pair, coming from the carb linkage on the driver side that I believe is kickdown wiring. There is about 6 inches of wire and then nothing. I cannot locate where that wiring may have once run to. There is also a single black wire also plugged into the kickdown linkage mechanism but it too is chewed away and there is no indication as to where it once ran.
In the service manual in the transmission disassembly section, there appears to be a 2-prong plug down on the transmission but the actual transmission only has one prong plug down by the vacuum modulator and the factory wiring diagram only shows a single orange wire leading down the transmission.
There was a black wire with an orange tracer that was part of the wiring that came out on the passenger side harness near the firewall. I assumed this was the wire (12V) that runs down to the single spade terminal on the transmission so I made that connection, but now I'm second guessing that. (as I said, in the manual wiring diagram it shows a single orange wire going to the transmission)
Can anyone help me identify where these wires need to terminate (and if possibly these are the reason the transmission wont' shift out of first)?
