Replacing some older ignition parts, couple questions
Posted: Fri Aug 30, 2013 2:09 pm
So on my '91 Toronado Trefeo (Trefeo has a slightly different engine set-up right?) I'm looking to replace some of the ignition setup. Taking a look under the hood gives me the impression that the spark plugs look pretty old and the wires looks stock. Keep in mind that I'm very new at this and my goals are to make the engine bay look cool and have good MPG
1) Is there really no difference between the Copper and Platinum spark plugs? It's only a couple dollars more so I really wouldn't mind spending the money if it makes even a little difference. I was looking at this: http://www.summitracing.com/parts/acf-41-902/overview/year/1991/make/oldsmobile/model/toronado
2) Is there a good way to know for sure that the parts will work with my car? Being new to this I'm really worried about getting the wrong pieces. These are the spark plug wires I'm looking at but I'm not sure if my distributor cap is a "HEI spark plug top" yet: http://msdignition.shptron.com/p/wire-set-super-cond-multi-angle-plug-socket-hei
3) After replacing those two things, how realistic is upgrading the distributor cap/rotor and electronic ignition to something like this?
http://msdignition.shptron.com/c/distributors_oldsmobile
Looking at MSD's website the only Distributor caps they list say V8, and since my car is a V6 it's safe to say that won't work? Do you have any recommendations for a V6? I've seen a few people say just keep the stock and upgrade the coil
4) The final part(?) is the Electronic Ignition. Just from forum recommendations I'm looking at this: http://msdignition.shptron.com/p/msd-digital-6al-ignition-with-rev-limiter?referring_products=pdp%7C1be9974390bb39acab393c24b0cbcadc
So as you can see I want to tune her up but I'm still trying to take in a bunch of information. I have yet to investigate what actual performance gains I'll get out of a new distributor cap and electronic ignition. I know for a fact I'm replacing the spark plugs and wires, so my focus is going into those for now but it might make sense to make some of these upgrades in parallel
If you have anything else you'd like to share regarding these types of upgrades I'd be eager to hear, thanks!
