Toronado 66 headlight actuators
Re: Toronado 66 headlight actuators
Hi, just to let you know that I'm still working on it, my car is now ready and I can improve this system. I will post more when I have results!
Kollege
- TOA Membership Number: 1441
Hi Francois,
thank you very much for sharing this! great job!
my popup lights are working...but one never can say for how long
Martin
Martin
Tuco
Hey François. How are your headlight actuators working for you?
I’m almost done with my 66 and now I’m having trouble with mine. I took them apart and cleaned/lubed everything but I can’t get them to work properly. One of them opens if I apply direct vac to it. The other one will work sometimes with direct manifold vac. I’m thinking maybe the rubber seals are leaking.
If yours work I would like to go the same route you took. Any info would be greatly appreciated..
My piston assembly (66) does not have the multiple alignment post. Is this something you added?
You may want to send Francois an email or PM since this post is 4 years old
what happens if a woman takes cialis
Systemic estrogen therapy <a href=http://cialis.lat/discover-the-best-prices-for-cialis>discount cialis</a> Ulrich CM, Neuhouser M, Liu AY, Boynton A, Gregory JR, Shane B, et al
sildenafil citrate dapoxetine side effects
The SNP significantly associated with both density and survival in both cohorts may be of interest in future research investigating polygenic risk scores for breast cancer risk and screening stratification purposes <a href=https://enhanceyourlife.mom/>buy priligy 30mg</a> Vitamin C can make these conditions worse
dapoxetine sildenafil brands
001N HCl, phosphate buffered saline pH 6 <a href=https://fastpriligy.top/>priligy and cialis</a>
