I'm removing all the trim on my '66 in preparation for painting the car. Can someone tell me how to remove the long rocker moulding without bending or breaking anything? I know there are some clips behind it, but does it just pop off, or do you pull up on the moulding or must you use a special tool? Also, in front and behind the door, the rocker moulding appears to be two pieces, or does it come off in one piece?
Dave
how to remove rocker moulding on a '66?
bluecab
Re: how to remove rocker moulding on a '66?
There are some small sheet metal screws with hex heads at the bottom edge. Once those are off the whole long trim will come off.
