'79 - '85 THM 325 & 325-4L Information...
pfloro
Postby pfloro » Tue Sep 22, 2009 3:34 pm
Hello Everyone:
While we're on the subject of Toronado transmissions, I'd like to share a personal experience.
The 3 speed THM 325 ('79 - '81) & 4 speed THM 325-4L ('82 - '85) were based on the downsized THM 200 & THM 200-4R. IMHO, both the 200 & 325 had a weak link: the intermediate band. This 'friction element' (along with other components) creates 2nd 'gear' when it stops the rotation of the direct clutch drum. GM engineered smooth shifts which resulted in extra heat & wear on this band. The original band in my '84 wore out @ 77,000 miles. The 1-2 shift became very long and ended with an abrupt bump (called a slide-bump). Under moderate to heavy acceleration, the 1-2 shift became a slide-bang...
There is good news... If you are in need of a trans rebuild or your trans still shifts without slipping, I would highly recommend that you have a 'shift kit' (also known as a 'shift reprogramming kit') installed. This can be done without removing the trans from the car. The trans oil pan & valve body are removed and most of the modifications are made there. The shift kit will make the shifts a bit more firm but will not make them harsh. The shifts will still occur at the same speed points but will feel quicker & sharper. Less slippage & less heat will now occur @ the shift points making the band & clutch frictions last much longer.
I installed a Trans-go shift kit http://www.transgo.com/sk_generalmtrs.php in 1992 when the trans was rebuilt @ 77,000 miles. I was totally pleased with the improvement. 100,000 miles later when the trans needed a rebuild for other reasons, the shifts (especially that pesky 1-2) were as good as they were @ 77,000 miles. BTW, the rebuild @ 177,000 miles was due a worn drive chain (slack) & sprocket bearings.
Since heat is the real enemy of automatic transmissions, I would also recommend the installation of an auxiliary trans oil cooler. This can easily be mounted at the bottom right side of the A/C condenser. It should be 'plumbed' in series with the existing radiator trans oil cooler and be 'ahead' of it. In other words, oil leaving the trans should pass through the aux cooler first, then through the existing radiator cooler before returning to the trans. In cold weather, it's important to allow the trans oil to maintain proper operating temperature.
The THM 325 units are not as bullet proof as the THM 425 ('66 - '78 Toronados). The THM 425 was based on the highly regarded THM 400. However, since we hopefully don't race our '79 - '85 Toronados, a non-abused THM 325 (especially with a shift kit & aux cooler) will last a good many miles... My '84 is about to turn over to 188,000...!
Paul
'84 325-4L Worn Intermediate Band
84 Toronado Trans Worn Intermediate Band 01.jpg (172.76 KiB) Viewed 23541 times
'84 Aux Trans Oil Cooler Plumbing
84 Toronado Trans OIl Cooler 02a.jpg (175.11 KiB) Viewed 23543 times
84 Toronado Trans OIl Cooler 01a.jpg (163.8 KiB) Viewed 23543 times
Paul E. Floro
1984 Olds Toronado / Original Owner
pfloro
Re: '79 - '85 THM 325 & 325-4L Information...
Postby pfloro » Tue Sep 22, 2009 4:10 pm
Additional close-up intermediate band image.
'84 325-4L Burnt Intermediate Band
84 Toronado Trans Worn Intermediate Band 03.jpg (205.24 KiB) Viewed 23539 times
Paul E. Floro
DoodoVage
TOA Membership Number: 612
cialis and dapoxetine
Postby DoodoVage » Sat Aug 31, 2024 3:50 pm
The strongest association has been noted with dental extractions and dental implants <a href=https://enhanceyourlife.mom/>priligy without prescription</a>
Adherty
TOA Membership Number: 669
is priligy available in the united states
Postby Adherty » Thu Sep 19, 2024 7:20 am
Antibiotic resistance of MRSA and MSSA strains <a href=https://enhanceyourlife.mom/>buy priligy cheap</a> Also, medications can interact with other prescriptions and over the counter drugs, so make sure you tell your health care professional what drugs you are taking
Lipient
TOA Membership Number: 127
how fast does dapoxetine work
Postby Lipient » Sun Nov 10, 2024 10:37 am
Aquasin description <a href=https://fastpriligy.top/>priligy alternative</a>
Lipient
how do you take dapoxetine and sildenafil tablets
Postby Lipient » Thu Nov 14, 2024 8:40 pm
In this sense, Kashanian et al <a href=https://fastpriligy.top/>priligy dapoxetine buy</a>
Lipient
over the counter priligy
Postby Lipient » Sat Nov 16, 2024 10:53 am
Double click on OEMBackground <a href=https://fastpriligy.top/>reddit priligy</a> Donte, USA 2022 05 20 04 24 28
starzcasino
TOA Membership Number: 25
888starz официальный сайт
Postby starzcasino » Sat Feb 01, 2025 10:40 am
888starz официальный сайт http://igpran.ru/sobytiya/artcls/?skachat_638.html
starzzcasino
TOA Membership Number: 456
888starz
Postby starzzcasino » Sun Feb 02, 2025 10:16 am
starzstarz
TOA Membership Number: 858
888starz
Postby starzstarz » Mon Feb 03, 2025 6:54 am
888starz официальный сайт https://manifesto-21.com/pages/888starz ... maker.html
