Parts List with Part Numbers and Prices
Anything that you can see under the hood, all underhood electrical, fuel, coolant and A/C.
Re: Parts List with Part Numbers and Prices
Postby Otto Skorzeny » Thu Mar 07, 2019 4:37 pm
OK, got it. Your Cord friend is handy to have around. I used the Speedi Boot for the outer boot.
Willysnut1959
Inner CV Boot Replacement
Postby Willysnut1959 » Fri Mar 15, 2019 5:14 pm
I received the inner CV replacement boots from Applied GMC (part # GM1-1.003.12) and found they were not correct for my car. I understand that the early '66 cars has a round drive flange and the later '66 models use a triangular drive flange. Have to send them back and continue to search for ones that will fit.
Marty - St. Louis, MO
1966 Toro
Postby Otto Skorzeny » Sat Mar 16, 2019 6:01 am
Damn! Remind me again where these came from.
Which flange does yours have? When you say early '66, do you have a serial number cutoff?
Willysnut1959
Postby Willysnut1959 » Sat Mar 16, 2019 7:47 am
Otto,
I bought them from Applied GMC. My inner CV joint is round and the CV boots from Applied GMS were triangular. I do not know the cutoff date or SN. The guy at Constant Velocity was the one that told me there were two types on '66 cars and that they could not find replacement boots for the round (early) type.
Marty, St. Louis, MO
'66 Toro
Postby Otto Skorzeny » Sat Mar 16, 2019 5:38 pm
Thanks. I'm going to have to take a look at mine. I have no idea what shape mine are.
Return to “Power train”
