This is for the front wheel drive Oldsmobile Toronado of 1968 - 70. Olds Toronado drive train with 455 engine. This final drive is a 10-bolt pan unit. Note, this definitely will NOT work for 1966-67 Toronados which had the 8- bolt pan and were used with the 425 engine.
$150, located near Richland, WA
1968-70 Final Drive
Re: 1968-70 Final Drive
The cross over shaft and mounting brackets are different, but it
will work if you change them as a set. Same situation with Cad
Eldorado, which required different brackets than Olds. Bruce Roe
