Torsion Bar Support Mounts
Chazzer
TOA Membership Number: 146
Postby Chazzer » Fri Jun 01, 2012 4:45 am
Howdy Toroites,
Anybody know where one can track down the mounts used between the torsion bar support brace and the frame rails? Theay are two separate cushions, upper and lower, with the upper having a steel sleeve molded to it.
Any suggestions are appreciated.
Cheers, Jim
TOA# 146
1970w34
TOA Membership Number: 38
Years Owned: 1970 multiple
Re: Torsion Bar Support Mounts
Postby 1970w34 » Fri Jun 01, 2012 7:46 pm
Not ever seen them except as salvage from decent cars. You can take the rubber parts (decent and undeformed) and gently bead blast them and then soak them in silicone. They come out good enough for re-use. The steel parts are less likely to be found intact but can be obtained from decent desert cars. CB
Chazzer
Postby Chazzer » Sat Jun 02, 2012 5:28 am
Thanks CB,
Cheers, Jim
TOA# 146
