Im lookig for complete steering wheel
Gas tank
Dash board knobs
69 toronado parts wanted
victor_olalde30
Re: 69 toronado parts wanted
Do you have the original steering wheel? If so, there are several fine companies that will restore it for you, even if large chunks of plastic are missing.
Is your tank rusted through? If not, or if it only has minor pin holes you can use a gas tank coating chemical to seal it up inside. These are usually referred to as Sloshing compound and are available from Eastwood. I used this on a 1964 Galaxie 500 in the early 90s and the tank is still smooth and solid inside.
