If you're diving into Path of Exile 2, you already know how important currency is. Unlike most games where gold is king, PoE 2 uses a deep and creative currency system made up of different orbs, scrolls, and shards. Among these, the Orb of Augmentation is one of the most-used, especially in early to mid-game crafting. If you're on a budget and need more resources, buy PoE 2 currency smartly and you’ll save both time and effort.
So, what exactly does an Orb of Augmentation do? Simply put, it adds a random magic modifier to a normal (white) item, turning it into a magic (blue) one. This is super useful when you're trying to build gear with specific affixes or using crafting benches to upgrade gear. For example, if you're working with Orb of Alchemy or Chaos Orbs, you'll want to prep your base items using Augmentations first to get the right prefixes or suffixes lined up.
To make the most of your PoE 2 currency, follow this handy tip: don’t waste your Orbs of Augmentation on just any item. Instead, use them on gear with the correct base type and item level for your build. You’ll get a lot more value when trying to roll desired affixes that work with your passive skill tree or Ascendancy class. This is especially true for weapons or gloves that need specific attack speed or elemental damage mods.
Farming Orbs of Augmentation in-game can be slow. They drop from monsters and chests, but not very often. A good farming strategy is to run low-level maps or repeat vendor recipes (like selling a magic item and a Scroll of Wisdom). But if that’s not giving you enough, it’s time to buy PoE 2 currency from a trusted source.
This is where U4GM comes in. It’s a great option if you’re looking to pick up some extra Orbs of Augmentation or even other popular currencies like Exalted Orbs, Orb of Binding, or Divine Orbs. Just one small purchase can give your crafting a major boost, especially during league starts or when you’re fine-tuning endgame gear.
Another great way to use Orbs of Augmentation is during bench crafting. If you have the right modifiers revealed through Essences or Harvest crafting, you can build solid magic items to upgrade into rare gear later. For example, start with a white helmet, use an Augmentation to roll a good +life prefix, then upgrade with an Orb of Alchemy for a chance at a rare item with solid stats.
To sum it up: smart use of currency like Orbs of Augmentation can seriously level up your game. Learn when to farm, when to spend, and when it’s better to buy PoE 2 currency to save time. Use these tips, plan your crafting, and you’ll be ready to crush Wraeclast in no time.
Recommended Article:PoE 2 How to Generate Frenzy Charges
Looking for cheap Orb of Augmentation? U4GM is your go-to!
StarryDawn
