Hi Folks,
I recently bought a 1966 Toronado Deluxe in Ojai, CA. I had the car shipped to Germany and started restoring it.
As usual with old cars things are never as they look at first sight....
I think I will have fun working on it for a longer time than expected.
Harald
- harascho
- IMG_7997.jpg (205.36 KiB) Viewed 48688 times
- IMG_7959.jpg (180.55 KiB) Viewed 48688 times
- harascho
some more pics.... and one of the worst area I found so far, the front windshield frame.
Does anybody have a solid Dash for me??
Harald
Harald
- IMG_8323.jpg (253.54 KiB) Viewed 48687 times
- IMG_8328.jpg (234.01 KiB) Viewed 48687 times
- harascho
Some info on the car, probably someone can help decode them.....
Harald
Harald
- sticker_2.jpg (160.07 KiB) Viewed 48684 times
- VIN_tag_1.jpg (78.37 KiB) Viewed 48684 times
That's a great car. I fully understand what you are saying about buying a car without first seeing it. You are however very brave for taking on such a project from so far away. I commend you for your vision and perseverance.
I hope you have the best of luck with your car.
Chris
Chris
taddpole
- TOA Membership Number: 983
- Years Owned: 69 Olds Toronado W-34
I would love to be with you when your are driving it around. I am sure it will be getting a lot of looks. Luckily it is almost as much fun to work on them as it is to drive them.
- harascho
some pics of the work done..
Harald
Harald
- IMG_8392.jpg (195.66 KiB) Viewed 48508 times
- IMG_8365.jpg (184.63 KiB) Viewed 48508 times
- IMG_8357.jpg (114.99 KiB) Viewed 48508 times
- harascho
and some more pics
- IMG_8485.jpg (228.74 KiB) Viewed 48508 times
- IMG_8471.jpg (221.09 KiB) Viewed 48508 times
- IMG_8450.jpg (250.36 KiB) Viewed 48508 times
- harascho
And here the last ones... situation as of today, rotisserie finished.... all ready for sandblasting
Harald
Harald
- roti_2.jpg (225.1 KiB) Viewed 48508 times
- roti_1.jpg (231.3 KiB) Viewed 48508 times
- IMG_8539.jpg (229.14 KiB) Viewed 48508 times
Harold,
I really like the rotisserie you set up! I wish that I had saved the dash piece from my 67 parts car -- you really could have used it as your car was rusted out. I makes me determined to find a way to save more of this stuff if I can because you never know when you'll need it. Keep up the amazing work and please keep posting pictures of your progress.
Tim
Tim
- harascho
Some earlier pics, parts which are sandblasted and awiting a treatment with KBS coatings.
The pic in an older message contains a welded hub. My front wheel bearings were shot, one inner race was turning on the hub instead within the bearing itsself. I had to weld the Hub and turn it back to spec in a lathe.
Harald
Harald
- IMG_8245.jpg (187.46 KiB) Viewed 48502 times
- parts reasdy for KBS preparation
- IMG_8243.jpg (212.64 KiB) Viewed 48502 times
- removing the upper A-Arm bushings
- IMG_8267.jpg (229.1 KiB) Viewed 48502 times
