If you had the hardcopy manual, you would see that they had a completely separate section, towards the end of the manual, that is for Toronado only. Things like engine and other mechancials, carbs, etc. that are essentailly the same as the other Oldsmobiles are in the front section. But you'll find everything at the back. And it will be labeled according to the same sections as for the other cars. Hence, if you're lookking for body section, which is say, Section 10 for other cars, it will be section 10-E, all at the end of the manual for the Tornonado Body section. The 67 manual is the same way. It's hard to browse the electronic version -- you can't flip the pages. Cheaper, but the hardcopy is better for working in a shop.
These cars are E body cars.
?.. 66 olds chassis service manual/Fisher Body Manual
Re: ?.. 66 olds chassis service manual/Fisher Body Manual
While looking for the 65 Fisher Body Service Manual I found the 66 Fisher Body Service manual so I thought I would pass it on.
Relax en Lima
Relax en Lima
Users browsing this forum: No registered users and 100 guests
