67 turn signal switch
Does anyone know where i can find a turn signal switch for a 67. Every switch I find says w/o tilt wheel. Can parts be poached off of that one to rebuild my existing?
Re: 67 turn signal switch
I needed a switch last year...not easy to find. I called about 50 different part suppliers....these switches are obsolete. I found one used for the price of $500.00. I had luck with cadillacsonly.com, they were great to deal with. A switch from a 67 or 68 Cadillac with tilt and tele will fit. Make sure you tell them its for a 67 Toro with Tilt and Tele.
Good Luck
Good Luck
- sharkeymark
- TOA Membership Number: 675
is this the same switch for the 1966 model?
