I based the upgrade on the Hydroboost system in the 78 Eldorado I bought for just this purpose. Hydroboost, for those not familiar with the system, uses the Power Steering pump to provide hydraulic pressure to drive a Hydraulic Power Booster. This entails running a line from the PS Pump to the Hydroboost unit and then back down to the Power Steering box. All these lines can be sourced for the Eldorado; I used the very new looking lines from the Eldorado.
One speedbump in the process is the difficulty of obtaining a Remanufactured Hydroboost unit; I ordered the last one in stock from RockAuto after finding that no local source could even get me one. It is also possible to send a unit off for rebuild; this is why I kept the unit I took from the Eldo for future use.
The usual gremlins popped up during the swap; I had to include the Master Cylinder due to differences in the piston actuator rod. I had to slightly modify the fenderwall to provide clearance for the end of the master cylinder as the new booster is a bit longer, and I had to make new lines to connect the MC to the distribution block and metering valve as they swapped the position of the front and back reserviors on the new MC. I also had to wrap the exhaust pipe with insulating material as the accumulator on the new Hydroboost unit is very close to the exhaust pipe.
You can either obtain a dual return inlet Power Steering pump or you can simply install a Tee in the existing return line for the standard PS pump; I did the latter as the Eldo pump does not look like it will fit in the Toro bracket. Eventually if I ever do the Serpentine belt upgrade I want I will probably use the Eldo pump.
The results, however, are well worth the effort. Braking is so fantastically improved it is a wonder they do not use this technology in more cars; my 1969 Toronado now stops even better than my 2001 Silverado and has much better brake feel. I have about 2 or so inches of brake travel before I hit a rock solid point and can easily lock the wheels up if I try. I went from developing a massive right leg to being able to feather braking with the lightest of touches. I highly recommend this for those that are willing to move away from a bone stock car.
